Author Topic: Fitting borbet A's  (Read 2803 times)
Offline WhirlyGTI
Re: Fitting borbet A's
« Reply #10 on: 16 January 2011, 09:12 »
Its not catching on the caliper it's just catching on the brake pad and there half worn so if I get new brake pads it will be even worse
So the rim is catching the edge of the brake pad as it turns ?
Yh the outside edge of where the bolts go through on the inside of the wheel is just catching on the brake pad and that's with half pads
« Reply #11 on: 16 January 2011, 09:30 »
I would guess your going to need 10mm spacers but that will leave you with a offset of 10 with means you could get arch clearance problems.
Offline gover87
  • mk3 gti 16v
Wheel swap
« Reply #12 on: 16 January 2011, 09:47 »
Just swap me for my bbs rk's :-)
Offline WhirlyGTI
« Reply #13 on: 16 January 2011, 09:50 »
Yh I will give 10 mm a go but I'll need to get longer bolts and should I go for a set of hubcentric spacers or just use universal
Offline gover87
  • mk3 gti 16v
Wheel swap
« Reply #14 on: 16 January 2011, 10:42 »
Id go 4 hubcentrics but it works out dear with spacers and bolts
Offline WhirlyGTI
Re: Wheel swap
« Reply #15 on: 16 January 2011, 10:48 »
ok thanks i dont spose you have a link to where i can get some from ? cheers
Offline gover87
  • mk3 gti 16v
Wheel swap
« Reply #16 on: 16 January 2011, 12:15 »
Ebay be cheapest mate
Offline WhirlyGTI
Re: Wheel swap
« Reply #17 on: 16 January 2011, 12:40 »
Don't Spose you got a link to the right ones on eBay have you mate be a great help cheers
Offline dom
  • Back in a Mk4
« Reply #18 on: 16 January 2011, 12:42 »
Just search for 5x100 10mm hubcentric spacers  :wink:
