Author Topic: having a bad day... bonnet catch  (Read 903 times)
Offline RyanVW
« on: 15 January 2011, 15:40 »
okay so i took apart the bonnet catch today in my mk3 cos it wasnt shutting properly.
I cleaned it, lubricated it then replaced it, but it was still catching and wouldnt shut properly so i narrowed it down to the cable, tightened this up a bit and it worked fine so i secured everything back in place, then shut the bonnet and now... i must have made it too tight because i cant open it  :cry:
iv took the grill off and i can hardly get at the bolts i can just about feel them with my fingeres but not undo them
any suggestions?!
Thanks
Offline RyanVW
Re: having a bad day... bonnet catch
« Reply #1 on: 15 January 2011, 17:00 »
problem solved, was a pain in the arse though!
gixer1400
« Reply #2 on: 15 January 2011, 17:33 »
for future ref how did you sort it ?  :huh:
Offline RyanVW
« Reply #3 on: 15 January 2011, 17:50 »
Well i already had the grill off which made the bolts just about accessible with a flexible socket wrench, undo them and the bottom one which is easy to get to then a bit of fiddling to free the bonnet from the catch...
hard to explain without pics but i found it pretty fiddly  :grin:
