Author Topic: Help, car wont start! Panic!  (Read 1706 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Help, car wont start! Panic!
« Reply #10 on: 15 January 2011, 14:09 »
15 mins won't be enough to turn the starter over if it's completely dead.
What are the voltage readings from the battery?
Offline Big Tone
« Reply #11 on: 15 January 2011, 14:12 »
Just getting a lift for a meter. How long should I charge it for?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Big Tone
« Reply #12 on: 15 January 2011, 15:25 »
Battery 12.2v drops to 11.8 when trying to start, just clicks loudly once when turning key
Offline Big Tone
« Reply #13 on: 16 January 2011, 08:24 »
BUMP
Need to sort this today, going to try;
1. Long charge 30mins +
2. Starter motor twa##ing
3. Bump start.
Anything else I can try?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 16 January 2011, 08:40 »
Don't bump start, you'll kill the cat/lambdas.
Clicking normally means the battery hasn't got enough juice to engage and turn the starter
Offline Big Tone
« Reply #15 on: 16 January 2011, 11:33 »
The cable between the battery and the starter had snapped at the battery end. Looked fine but fell apart when pulled.
Need to remake connection.
