Author Topic: 1988 8v gti questions  (Read 14137 times)
Offline George_HH
« on: 22 May 2003, 11:48 »
sorry to ask but........what injection system would this year golf have? same question for an 89 was there a change? basically a description of the various systems used and dates, pros, cons etc...
also is there a guide or similar anywhere on how to change the gear shift bush that stops reverse being selected unless its pushed down as mine is quite worn and can be slipped across if your too heavy handed - i've got used to it but my dad drives the car occasionally and it worries me!
much appreciated. GH
« Last Edit: 01 January 1970, 01:00 by -1 »
Bored............i'm the chairman of the Bored....
Offline richandhazel
Re: 1988 8v gti questions
« Reply #1 on: 22 May 2003, 15:02 »
Quote
You will either have the K-Jetronic CIS or a variation of it, or it will be the Digifant system. Engine code PB use the Digifant system that is fully electronic.
This may help you identify which system you have:-
http://homepage.ntlworld.com/richandhazel1/Fuel/Fuel_system.htm
Offline George_HH
« Reply #2 on: 22 May 2003, 18:02 »
great site, i have one of the digifant's.
thanks for your help.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline Flip
« Reply #3 on: 01 June 2003, 23:59 »
re your gearshift problem , you need to replace the plastic ball and housing at the bottom of the gear stick, its a bit fiddly but its only about 9 quid for the kit, theres an article in the june issue of The Golf , tells you how to do it .let me know if you cant get a copy.
Offline George_HH
« Reply #4 on: 02 June 2003, 11:27 »
yeah, i figured that out when i took gaitor and suround off to have a peek. i'll have to pop out @ lunch and see if i can get hold of a copy of junes The Golf.
if not could you scan and e-mail to me?
