Author Topic: Best place to buy an ARB  (Read 2022 times)
Offline CraigDavieBeattie
  • Golf mk5 Sport Tdi 4motion
« on: 13 January 2011, 20:08 »
Alrite fellas, just wanted to know wheres best for buying an uprated ARB? with it being lowered roughly 70-80mm i am looking to buying one with the loop to save the driveshaft being re-done within a matter of time i guess. So wheres best to buy these?
Cheers, Craig.
Offline vwfiend
Re: Best place to buy an ARB
« Reply #1 on: 13 January 2011, 20:14 »
Probably a neuspeed from awesome gti. I'm still tryin to save for the 28mm rear beast. Their guaranteed not to rub on the front as I've heard that some whiteline do and eibach don't have the 'big loops' and FK are pretty pony.....
« Last Edit: 13 January 2011, 20:46 by vwfiend »
Offline Dave_IOW
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline andc1
« Reply #3 on: 13 January 2011, 20:26 »
looks good the fk one, mk1 tt's fit, theres a link on edition 38 somewhere
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 13 January 2011, 21:20 »
yes mk1 TT ARB and longer drop links, fits perfectly from the pics I've seen :wink:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 13 January 2011, 21:23 »
neuspeed.. recommended by grandmasterpatch i believe..
Offline b1gdub
  • MK4 1.8T AGU
« Reply #6 on: 14 January 2011, 09:30 »
I'm about to fit an R32 arb from vw onto mine and will be using adjustable droplinks with it.
jamie16v
Re: pipe internal diameter size. (TIP vac off)
« Reply #7 on: 14 January 2011, 09:43 »
Is that the same fitment then as r32 use different wishbones?
Offline b1gdub
  • MK4 1.8T AGU
« Reply #8 on: 14 January 2011, 09:50 »
The R32 one is the same as the TT but thicker (23mm) and runs under the driveshaft to eliminate the driveshaft/arb fight. And using adjustable droplinks I can attach the arb to my standard gti wishbones.
jamie16v
« Reply #9 on: 14 January 2011, 10:27 »
Thats interesting.
