Author Topic: how do I get out a rounded off caliper bolt?  (Read 2534 times)
Offline tsr_adi
« on: 13 January 2011, 16:46 »
I was going to fit my gti brakes today but the bottom caliper bolt I need to undo to swing the caliper up is rounded off good and proper. Tried hammering in an allen key bit and a torx bit but its not having it. I don't have a welder to welding on another bolt is out of the question. Any ideas?
Offline emery1990
Re: how do I get out a rounded off caliper bolt?
« Reply #1 on: 13 January 2011, 18:19 »
http://www.screwfix.com/prods/96028/Van-Car-Accessories/Sockets-Hex/Irwin-5-Piece-Bolt-Grip-Nut-Remover-Set?cm_mmc=GoogleBase-_-Datafeed-_-Van%20and%20Car%20Accessories-_-Irwin%205%20Piece%20Bolt%20Grip%20Nut%20Remover%20Set
Could try these, but arnt the caliper bolts 17mm, if so they prob do other sizes for sale. Mines opposite to yours and won't screw in, thats confusing!
Offline tsr_adi
« Reply #2 on: 14 January 2011, 10:55 »
mine have a round head and are torx bits inside. I'm gonna try ramming a socket on it or maul grips. But in my experience they can be real tight  :angry:
Offline LowlifeDubber
« Reply #3 on: 14 January 2011, 11:18 »
Warm it up and try and chisel it round?I might have a spare one here if you fluck it up proper.
Offline alexd
« Reply #4 on: 14 January 2011, 12:38 »
Buy some extruders?
Offline emery1990
« Reply #5 on: 14 January 2011, 15:42 »
Are they hardened steel, maybe you could get some small stilsons on it, will probs be too hard for the teeth to bite though
Offline AudiA8Quattro
« Reply #6 on: 14 January 2011, 23:50 »
Irwin extractors will move anything.
Offline Diamond Hell
  • Opinions я Us
« Reply #7 on: 15 January 2011, 08:59 »
Or more likely shear off.  :grin:
Get some heat on it is probably your best bet...
Or go find a set of 280mm brakes, complete with the hubs and complete a worthwhile upgrade.
Offline tsr_adi
« Reply #8 on: 15 January 2011, 10:21 »
Already bought vented 239mm discs and brembo pads now  :grin:
I've got some small stilsons, not sure if theres enough room in there to get a grip on though. I'l have to remove the rubber bit that surrounds it 1st...
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 15 January 2011, 12:06 »
+1
LOADS OF HEAT AS DH SAID!! but the extractors might take the bolt out
*****MK3 Anniversary*****
*****MK4 GTI T*****
