Author Topic: water leak in boot  (Read 4372 times)
Offline dom
  • Back in a Mk4
Re: water leak in boot
« Reply #10 on: 13 January 2011, 23:35 »
if it has a roof aerial also check the rubber seal at the base
Don't suppose you've got a part number for the rubber seal do you?  :smiley:
or you can do what i did when i got my clear rear lights that always let water in.
i put a silicone beed on both side of the gasket then fitted it to car wile silicone was wet.
has never leaked since  :laugh:
Talking about the aerial  :wink:
« Reply #11 on: 13 January 2011, 23:38 »
Silicone will only do so much, some of the cheaper lamps let in water through the casings.
@ Dom, I don't think you can get the seal on its own, when I asked I was told it was only available with the base.
Offline stainesy
« Reply #12 on: 13 January 2011, 23:39 »
yeah i no i had to seal all parts of my rear lights.
Offline dom
  • Back in a Mk4
« Reply #13 on: 13 January 2011, 23:58 »
Cheers Wayne :afro:
In that case does anyone have a part number for the base? :smiley:
Offline LowlifeDubber
« Reply #14 on: 14 January 2011, 00:24 »
This might be of use.
Offline javalin
« Reply #15 on: 14 January 2011, 08:17 »
failing that - a healthy dose of gasket maker also works. (think black bath sealant)  :grin:
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline lee mk3
« Reply #16 on: 14 January 2011, 11:37 »
cheers
Offline stainesy
« Reply #17 on: 14 January 2011, 13:17 »
yeah i used tiger seal  :laugh:
Offline boneybradley
  • Back in a Mk3...
« Reply #18 on: 14 January 2011, 14:02 »
I do know hella sell aerial spares inc seals (or sold them a couple of years back!). find a hella dealer and ask if you want the real thing
