Author Topic: petrol issues  (Read 2446 times)
nige_s
Re: petrol issues
« Reply #10 on: 13 January 2011, 09:57 »
I'm getting about 27-30 mpg with mixed driving.  1.8t's have never been that economical even with a light right foot, give them any amount of medium right foot and fuel just gets dumped through those injectors.  We had a factory fresh one about 10 years ago, the wife could get that to push about 35mpg on a longish journey.  Wasn't really any issue then as fuel costs had only just start to soar.
When I first started driving in 1990 I can remember filling up at 35p per litre, them wer days lad.
« Last Edit: 13 January 2011, 09:59 by nige_s »
Offline dolphinfriendly1012
Re: petrol issues
« Reply #11 on: 13 January 2011, 10:03 »
I suspect its just the cost of fuel that's the problem. When it is all but 6 quid a gallon you don't even get quarter of a tank for 20 notes so it aint going to last long whatever you drive. If your like me and remember when fuel was cheap and still go and stick a tenner in thinking that will last the week but lucky if it makes it back from the petrol station on it now! :shocked:
I passed my test in 95 and i had a mk1 golf that used leaded fuel at 40 odd pence a litre and that was expensive as a poor student. oh happy days.
nige_s
Re: petrol issues
« Reply #12 on: 13 January 2011, 10:06 »
Yup, I reckon the same.  Be interesting to log how many people think they have a fuelling problem or leaking tank every time fuel prices increase.  I tend to always fill up so the mileage per tank is pretty much constant, it's just the debit card receipt that changes.
If you only ever top up in £20 lumps you will notice a reduction in miles per cost as you are basically buying less fuel.
Offline andy223
Re: petrol issues
« Reply #13 on: 13 January 2011, 11:33 »
i do short runs and the trip seems to be around 20-25 but i like to hear the turbo whistle  :tongue:
best ive had on a long run was nearly 42/45 (or nearly 50 driving like an old women @ 55mph) - mines remapped
Golf GTI MK4 1.8T AUM |
dellenty69
Re: petrol issues
« Reply #14 on: 13 January 2011, 12:31 »
Im the mate!  he does average mileage, alot of stop start type of driving ( same as me) £20 a week with this kind of driving gets me around 80 miles, we both live around 2miles from work. so car never warms up fully, this is obviously using more fuel.
i can 90 miles on the motorway and use £10 worth of fuel, but around our town its crap.
we both filled up with £20 last sat, i only just put another £20 this morning. but hes used nearly £60 worth i think.
i done a quick scan on his and got the fuel bank one rich code, but with that was the pressure drop between turbo and throttle. (dv) as its a standard bosh dv i would imagine its shot, causing the other code.
i said to him it could be a possible MAF failure. as it does seem to use alot of juice.
james
jamie16v
Re: pipe internal diameter size. (TIP vac off)
« Reply #15 on: 13 January 2011, 12:46 »
Could also be he is doing longer journeys with a hotter engine and you may be doing alot of stop starts up and down the gears ect
Offline simon20vt
Re: petrol issues
« Reply #16 on: 13 January 2011, 16:34 »
My bank one rich code was cured when i got my lambda sensor changed. do the D.V put a forge 007p on instead as its stronger than standard, if thats what the problem is. See if that cures the bank 1 running rich, if it doesn't i would say its the first lambda sensor, as the golf has i belive. one on manifold, and one on the cat? someone correct me if i am wrong  :smiley:
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: petrol issues
« Reply #17 on: 14 January 2011, 01:22 »
i had the same problem. I went for my remap at R-tech and they checked the car over and found it was the MAF that was giving off dodgy readings so that might be a good place to start, now im saving a fair bit on fuel as i do about 650miles a week  :smiley:!  Get a Gen one tho, mine was a new aftermarket one and it was giving off dodgy readings, causing the engine to over fuel!
VW charge about £70 for a new one, best price i could find even at mates rates!
Or find someone with VAGCOM, you'll soon find out if theres a problem
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline houston
Re: petrol issues
« Reply #18 on: 16 January 2011, 10:43 »
colder weather also affects your cars mpg, does your temp needle reach 90? once its all fully warmed up do you still get petrol smell from exhaust? could be temp sender telling ecu its still cold and running rich.
mines averaging jst under 30mpg on short journeys, but the other day i managed nearly 45 mpg, 40mph in 5th for a few miles.
i actually find these engines quite good on mpg compared to other turbo'd engines, mates 200sx seemed to just chuck the petrol straight our the exhaust!
