Author Topic: engines and what fits what  (Read 7661 times)
Offline jimmyhodge
« on: 11 January 2011, 14:31 »
Ok to the knowledgable ferternity out there does a mk3 golf 2.0 8v block (bottom end) fit onto mk2 1.8 gti head? Is it the same casting? Obviously pistons will be different etc etc. I just want to know if the bolts will match up etc etc.  :smiley:
ohhhhh shinnnnyyyy! Story of my life...
Uploaded with ImageShack.us
Offline Benrevs
Re: engines and what fits what
« Reply #1 on: 11 January 2011, 14:51 »
Mk3 2.0 bottom end works best with the mk2 pb head, it flows better than the mk3 one. It is a direct fit so no problems there.  Also any engine will fit with a mix of parts and an angle grinder/welder!!
Offline maisy
  • feelin the dub love
« Reply #2 on: 11 January 2011, 14:58 »
I have this set up works fine and dandy, feels like a more punchy engine  :wink:
[/img][/URL]<br /><br />KEEP CALM AND CARRY SPARES<br />
Offline Benrevs
« Reply #3 on: 11 January 2011, 15:12 »
I had one too, I am planning on doing it to my current one. Combined with a ported, polished gas flowed head, it makes for a powerful engine. Mine used to pull like a train.
Offline jimmyhodge
« Reply #4 on: 11 January 2011, 16:19 »
So are both the 8v and 16v abf mk3 bottom ends the same? Rod lengths etc etc?   :smiley:
Offline rob.043
« Reply #5 on: 11 January 2011, 16:44 »
No, they are different beasts. The mk3 8v bottom end, pistons and all, can be bolted up to your mk2 head, but not a 16v ABF bottom. The ABF code is for the mk3 16v engine only, there are various codes for the mk3 8v engine, the minor adjustments for fitting one in to a mk2 vary slightly depending on exactly what code of engine you use.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 11 January 2011, 17:15 »
sorry to be a pain.. why would you choose to keep it 8v over going 16v for not much more effort ??
Offline danny_p
« Reply #7 on: 11 January 2011, 21:59 »
Just ABF it, mk3 16v block head, loom and ecu  it all just bolts up and plugs in anyway
all the VW's have gone bar 1.
Offline berni29
« Reply #8 on: 12 January 2011, 07:45 »
Hi
So if I fit a MK3 8v bottom to my Digifant will it need a remap/chip or does the system have enough room to adapt?
Many tks.... Berni
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 12 January 2011, 09:06 »
It'll live.
Crossflow 8V head is a further upgrade over those mentioned already and facilitates the fitment of ITBs should you wish to go properly mental in an 8V.
