Author Topic: Rear spacer question  (Read 2034 times)
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« on: 11 January 2011, 09:28 »
Probably a stupid question, but if I just put 20mm spacers on the back and none on the front would that cause any issues?
Re: Rear spacer question
« Reply #1 on: 11 January 2011, 09:35 »
Nope , none at all  :smiley:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #2 on: 11 January 2011, 10:18 »
Okay cheers, just wanna bring the rear wheels out a bit  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 11 January 2011, 10:36 »
Will be fine mate.. Why not push the fronts out a tad as well ??
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #4 on: 11 January 2011, 10:57 »
Yeah I might do, the spacers are £50 and money is tight so wanna try the back first to see how it looks. Then next month maybe get 10mm fronts.
Offline Rhyso
« Reply #5 on: 11 January 2011, 11:00 »
Dim problem with spacers only the rear
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #6 on: 11 January 2011, 12:26 »
Dim problem?
Offline Rhyso
« Reply #7 on: 11 January 2011, 12:31 »
Dim problem?
 :rolleyes:
No problem
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #8 on: 11 January 2011, 14:40 »
Cool beans! Cheers for the pics rhyso!  :wink:
Offline Grand Master Patch
« Reply #9 on: 11 January 2011, 18:41 »
Will work very well,the track on a mk4 is 10mm wider up front so doubling what you put on the front at the back will make the front and rear wheels line up :wink:
