Author Topic: Just viewed a GTI......Is this ok though?  (Read 1808 times)
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: Just viewed a GTI......Is this ok though?
« Reply #10 on: 10 January 2011, 20:07 »
Would the car over heat on idle if left if the head gasket was on the way out??My old VR use to do this if I left it for a while not as much though.
Golf Gti
Offline bubbaboo
« Reply #11 on: 10 January 2011, 20:17 »
not necessarily as long as the coolent system is ok and still circulating it wouldnt over heat
« Reply #12 on: 10 January 2011, 20:46 »
Try and give it a good run before buyig it, if it clears all well and good if not walk away.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #13 on: 10 January 2011, 20:53 »
Excellent help as always......thanks guys  :smiley:
Will give it a good run tomorrow and see what it is like on return. A good run should be how many miles and should I really hammer it?
Offline snifferdog
« Reply #14 on: 10 January 2011, 20:54 »
Depends if the owner is going with you or not!  :grin: Go as far as you can would be best.
« Reply #15 on: 10 January 2011, 21:14 »
Nope but a good mixed run of around 20miles if you can.
