Author Topic: 4ltrs of castrol gtx £10  (Read 2447 times)
Offline Dan J
« on: 05 January 2011, 17:24 »
popped in Asda today to get a few bits and got 4ltrs of castrol gtx 10w-40 and 4ltrs of 15w-40 for £10 each, bargain :cool: normal price is £20 i think. get in there guys. :wink:
Offline suki
Re: 4ltrs of castrol gtx £10
« Reply #1 on: 09 January 2011, 17:14 »
hi mate i wanted to no what oil to use for my gttdi 110/115 with 140k? so then i can get my self down to asda and no which oil to get lol
Offline Dan J
« Reply #2 on: 26 January 2011, 02:10 »
look in your manual it will tell you in there;) 15w 40 should be fine in deisels but definatly check your manual because the gttdi's might need a more specific oil.
Offline Khare
  • The bear that khares
« Reply #3 on: 26 January 2011, 02:20 »
You want a 5w/30 in the TDI, otherwise the oil is too thick for the turbo  :smiley:
Offline robz
« Reply #4 on: 26 January 2011, 07:24 »
Good shout!!
Offline danny_p
« Reply #5 on: 26 January 2011, 16:47 »
PD engines need an oil that is approved for use in them.
due to the forces deing transmited in the valve gear the oil must have a very very high file strenth and be resitant to shear forces.
put unsutable oil in and the cams and tappets will chew each other to bits
all the VW's have gone bar 1.
Offline Toby
  • Car - less
« Reply #6 on: 26 January 2011, 16:51 »
saw this a few weeks ago  :cool:
Currently down under
Offline Dan J
« Reply #7 on: 26 January 2011, 19:19 »
hence why i said check the manual first, mines not a pd engine so not too fussy on specific oil, but yes pd engines have to heve the specific grade stated by Khare.
Offline danny_p
« Reply #8 on: 26 January 2011, 19:53 »
range of oils are used in them there PD enignes,    5/30  through to 0/40 w    our TDI's are both running 0/40w
Offline Toby
  • Car - less
« Reply #9 on: 26 January 2011, 19:58 »
alll gone in my local asda's and i went to both of them  :lipsrsealed: :laugh:
