hello people
just a quick question b4 i go mad stripping more out then needed
cars just failed mot 2 things
high emissons think ive sorted that !!
now the problem on the n/s ft subframe (rear engine support) i have a hole size of aa battery by horizontal bolt on wishbone i can weld it ,just wondering if im able to remove the two bolts holding the wishbone on ie one going to floorpan VERTICALLY and HORIZONTAL ONE ,can i get away with out having to remove trackrod ends ball joints etc just need some space and i would imagine the heat from welding will melt the wishbone bush by said bolt ,just neeed it to drop move by a couple of inches. note not welding wishbone just subframe hole ,please advise its a job for tomorrow hopefully.max
