Author Topic: HALL SENDER  (Read 1485 times)
Offline dumbnut
HALL SENDER
« on: 03 January 2011, 22:54 »
I have searched the forum and there seems to be loads of info about these sensors. Does anyone know how these work. my GTI is showing 00515 hall sensor signal outside tolarance. Does this need changing as someone  said you can unplug them once the car has started. is this sensor conected to the crankshaft sensor and should i change this first. Money running out
Offline dom
  • Back in a Mk4
Re: HALL SENDER
« Reply #1 on: 04 January 2011, 08:00 »
The hall sensor is located on the side of the distributor. The first thing I would do is check that your timing is correct, if it is then you may need a new hall sensor  :smiley:
Also can you rev beyond 5000rpm or is it limited?
Offline dumbnut
Re: HALL SENDER
« Reply #2 on: 04 January 2011, 22:12 »
After reading about the 5000rpm problem i decided on the way home tonight to try it. as soon as i got 5000rpm bingo the car shut down. I have cleared all the codes down but have not had time to recheck them. might try timming before i spend any mre money though.
Offline boneybradley
  • Back in a Mk3...
Re: HALL SENDER
« Reply #3 on: 04 January 2011, 22:14 »
also check the wiring for the sensor as it can crack with age causing the same issue and a new sensor wont fix it!!
Offline dom
  • Back in a Mk4
Re: HALL SENDER
« Reply #4 on: 04 January 2011, 22:17 »
Also if you do end up replacing the sensor, don't do what I did and foget to plug it back in  :rolleyes:
I drove around for 2 weeks thinking that the problem wasn't solved until I realised my mistake  :lipsrsealed: :laugh:
Offline Bellend
Re: HALL SENDER
« Reply #5 on: 04 January 2011, 22:21 »
Mine refuses to run with it disconnected. :undecided:
Where all my moneys went.
Offline dumbnut
Re: HALL SENDER
« Reply #6 on: 04 January 2011, 22:28 »
if it runs without it whats its for. Quite a pig to change from reading the forum.
Offline Leon27
Re: HALL SENDER
« Reply #7 on: 04 January 2011, 22:31 »
Bellend - If you don't have a crank sensor then it would die as it doesn't have another reference point for the ECU as to where TDC is. My Mk2 did this, whole broke off when I shut the bonnet  :sad:
OP, glad ure nearly there :) +1 to Dom's advice to get the static timing checked first, hopefully its just one tooth out. If the belt isn't new and has slipped I'd be changing it with a new tensioner
