Author Topic: ARGHHHH!!!! VAGCOM reading Error? mk3 gti  (Read 1218 times)
Offline muzo26
« on: 03 January 2011, 18:14 »
 What am i doing wrong plugged in the vagcom OBDII and it started to read and came up with error!!!! :sad: :sad:
Re: ARGHHHH!!!! VAGCOM reading Error? mk3 gti
« Reply #1 on: 04 January 2011, 10:19 »
what error was it? was the ignition switched on, and did the led in the vag-com cable light up
Offline muzo26
« Reply #2 on: 04 January 2011, 18:26 »
 It is a mac code reader OBDII. When i plugged it in it had a menu come up on the screen, and then i selected find fault codes then it started but then came up with Errr? the engine was,nt running and i tried it with ignition on and off.
  I have got a mk3 95 colour concept i have had no problems with it till friday last week, it was firing on 3 cylinders and then on saturday it suddenly won't start?
   I have got sparks at the plugs and fuel going through the lines so i was hoping it,s an electical
fault? :undecided:
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 04 January 2011, 19:51 »
fault? :undecided:
Where are you based ??  Only asking to see if there is someone on here local to you that could help you.
Offline muzo26
« Reply #4 on: 04 January 2011, 20:30 »
    Newport South Wales?
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 04 January 2011, 21:56 »
Too far from me but there are plenty of members in the South Wales area....just ask away and for a few beer tokens I am sure someone will help you Buddy  :wink:
