Author Topic: Anyone done this before?  (Read 3261 times)
Offline AlexMozza
Re: Anyone done this before?
« Reply #10 on: 02 January 2011, 20:29 »
Even better, tell them to go for air coolled, just get rid of the rad all together :/
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline danny_p
« Reply #11 on: 02 January 2011, 21:36 »
pikey get you home rad fixes.
Kseal
get plires and bend back and crush the leacking tube.
mix up a big dollop of body filler and really work it into the leacking area.
egg white is an old old trick that dose sort of work,  i'll seal weeps and small holes splits in low pressue systems, but if K seal won't fix it egg white has no chance.
btw radweld is crap and rarely works
all the VW's have gone bar 1.
Offline AudiA8Quattro
« Reply #12 on: 02 January 2011, 22:04 »
Egg white does work, but only with small leaks.
I've always found radweld to work fine.
Offline Gecky
« Reply #13 on: 02 January 2011, 22:05 »
Hi I've heard of people doing this but even if it did work would probably knacker the radiator and god knows what else. I had an astra g sri with a leaky rad, and put kweld in it job done available from motorist discount if you have one.
One more suggestion tell him to do what I did sell the punto for scrap and buy a gti  :smiley:
My bad I meant k seal not weld  :laugh: thanks Danny_p
Offline sharki786
  • GOT BOOST??
« Reply #14 on: 03 January 2011, 16:32 »
that does work!!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline MrRogers
« Reply #15 on: 05 January 2011, 00:26 »
+1 Kseal is good stuff  :smiley: ..for a quick fix not sure on how long it will lat tho lol
2000 Golf MK4 1.8 AGU black magic, Custom Code stage 1 remap, Forge 008, Simota Aeroform CAI, G60/VR6 Combo, Weitec GT Hicon coilovers, Golf GTI MK5 18" Monza style alloys, 10mm H&R spacers front + 20mm H&R spacers rear, OEM Polo MK5 aerial, Whiteline front ARB + Whiteline droplinks.
Offline danny_p
« Reply #16 on: 05 January 2011, 10:03 »
K seal sealed up the saxo its radiator leacked like a sive and  it kept all the water in it for a year after the k seal, tho after that it did start useing water again but that radiator was completly pox ridded and did get batterd
Offline Guy
« Reply #17 on: 05 January 2011, 10:11 »
rad weld is horrible stuff... I lost a heater matrix and a water pump to that sh!t
if you HAVE to use any pikey stuff like this then use WYNNS RADIATOR STOP LEAK
http://www.wynns.be/index.php/en/x/30?cId=29&bId=558&pId=55864
or simply just replace the radiator yourself?
« Reply #18 on: 05 January 2011, 12:07 »
Its all the same stuff.
Any coolant leak fix is supposed to be used ONCE.
The problem becomes when people keep putting it in(or previous owners have), that's when the problems start.
