Author Topic: (((((VR6 STANDARD - TO - VR6 TRACK ))))))  (Read 39506 times)
Offline mmaattyyg
  • i need anger management as i dont take advice well
Re: (((((VR6 STANDARD - TO - VR6 TRACK ))))))
« Reply #170 on: 03 January 2011, 01:10 »
I'd just do it anyway. On a serious not at the end of the day its your car. If you eant it to have a harness bar with no cage fitted get it done. Just look through trackday and motorsport as its quite usefull.
lemski at anypoint of this thread did i say i want a harness bar without a cage fitted ?
i need anger management as i dont take advise well ......
Offline mmaattyyg
« Reply #171 on: 03 January 2011, 01:11 »
o
« Last Edit: 03 January 2011, 04:56 by mmaattyyg »
Offline Bellend
« Reply #172 on: 03 January 2011, 01:12 »
:afro:
I told you  DH would give you some stick but at the end of the day, LOADS of advice has been put in front of you.
You start following and you'll gain the respect of everyone.
Strut brace harnesses are stupid as everyone has said, I don't want to go into it as I'm sure I don't know every reason why, other then the fact of why you would want your seatbelts on the suspension turrets? Also from what I've been reading off DH, it's something to do with the angles? I assume you won't want to be putting pressure on the upright of the seat, if that gives way then I'd imagine at the wrong angle of belt then your back would too.
The fibreglass panels are a good idea but you need to make a priority list.
My main priorities would be in random order:
PROPER CAGE, do much research and listen to the track day "experts" here.
Suspension, coilovers are great but are they really better then a dedicated shock/spring kit with damper adjustments?
Brakes, how old is the car? Does it have the 280mm brakes? Would it be worth upgrading to the 288mm with DECENT pads, discs and fluid? Would it be worth going 312mm? How serious are you?
TYRES. No point in doing it all on budget tyres is there?
Then I'd look into some decent seats. Again, I've not got a great idea on these, ask the track boys.
Wheels, you want some nice, light wheels right?
THEN when you've got ALL that sorted, I'd look at lighter panels, you seem set on chassis work, before you've got a cage?  :rolleyes: and the engine mods. Turbo if you're really into it maybe.
Your budget will depend how serious you are, as will how quick it will be.
Chuck a grand at it and you may have a bit of a toy.
Chuck 10 grand (at a complete guess) and you may have a bit of a weapon.
Where all my moneys went.
Offline thatwillis
« Reply #173 on: 03 January 2011, 02:18 »
Lovely pm..
answer the question then dick head !
surprised its not in caps...
On here you might not know anyone but you get an idea what there like in the way they express themselfs. How they build their posts, how they put themselfs across, how helpful they are etc. You have people here trying to help and your still acting like a c u n t.
I'm not building a track car but i have had the fact that I need a harness bar drummed in to my head and not attach my harness to the rear strut brace because its dangerous i might just go get one...for the sake of it!
Offline Khare
  • The bear that khares
« Reply #174 on: 03 January 2011, 02:20 »
 :smiley:
« Last Edit: 03 January 2011, 04:31 by Khare »
Offline mmaattyyg
« Reply #175 on: 03 January 2011, 02:26 »
o
Offline NYSoul
« Reply #176 on: 03 January 2011, 02:32 »
Matty.. I am not having a dig here, its a serious question.
What are you expecting to spend on the VR to make it track worthy?
Offline mmaattyyg
« Reply #177 on: 03 January 2011, 02:38 »
o
« Last Edit: 03 January 2011, 05:02 by mmaattyyg »
Offline NYSoul
« Reply #178 on: 03 January 2011, 02:56 »
Again... I'm not having a dig but spending 5K on that is not really going to get you that much. The engine set ups you are talking about would be at least 4K.
Which would leave you
Box, Brakes, Cage, Suspension, Wheels, Tyres and Body to do on £1,000  ???
You can't scrimp when you pimp mate  :wink:
If you had £15,000 to throw at it would still be miles behind this at the end of a lap.
http://cgi.ebay.co.uk/VW-Vento-VR6-Track-Race-Car-Built-VW-Not-golf-/150536117083?pt=Automobiles_UK&hash=item230ca6db5b
Like I say, I aint having a dig but if you have £5,000 go and buy a half decent built track car and go enjoy it
Offline mmaattyyg
« Reply #179 on: 03 January 2011, 03:02 »
O
« Last Edit: 03 January 2011, 04:31 by mmaattyyg »
