Author Topic: will it start wont it !!!  (Read 1911 times)
Offline bmotormad
« on: 31 December 2010, 18:42 »
I have a 97 vr that sometimes wont start. Central locking operates fine, open the door put the key in turn key and engine roars into life..........OR........ turn the key and nothing..... not even a click, dash lights come on its just a lottery if it starts  :angry: :angry: :angry:
Offline snifferdog
Re: will it start wont it !!!
« Reply #1 on: 31 December 2010, 18:45 »
Sounds like the starter or solenoid?!
Offline dumbnut
« Reply #2 on: 31 December 2010, 19:06 »
sounds like transponder problem to me if you have one fitted. what model have you got. some one will proberly tell you to change the ECU relay. :grin: :grin: :grin:
Offline snifferdog
« Reply #3 on: 31 December 2010, 19:08 »
Hmm good point, if theres no click then it could be the transponder, but yeah my money is on the ECU relay!  :grin: :grin: :lipsrsealed:
« Reply #4 on: 31 December 2010, 19:30 »
Ign. switch
Offline bmotormad
« Reply #5 on: 02 January 2011, 13:16 »
Car is not stored locally so i cant check on model but was registered 07/11/97, so i was asuming it was a obd2 as i thought they changed over in 95/96??
Must have missed the ecu thread !!!
Offline Deano2711
  • 1992 VR6
« Reply #6 on: 02 January 2011, 13:46 »
Ign. switch
This is where I would start as well.
Offline Bellend
« Reply #7 on: 02 January 2011, 14:03 »
Starter solenoid or ignition switch if it's all fine except for the starter.
Sounds more igntion switch based if it's very random though.
Where all my moneys went.
Offline AudiA8Quattro
« Reply #8 on: 02 January 2011, 22:43 »
« Reply #9 on: 04 January 2011, 10:17 »
if it does it again, try jumping red/black wire terminal on starter with 12v direct frombattery. if that works take p[lug off ignition switch and jump red wire to red/black wire. if that works its the ignition switch, if not its the wiring. the factory fitted and some aftermarket alarms are spliced into the red/black wire so if fitted that could be the cause.
id go with ignition switch though :)
