Author Topic: 1.8SPi won't rev and won't change up Auto UPDATE  (Read 2510 times)
Offline LowlifeDubber
Re: 1.8SPi won't rev and won't change up Auto UPDATE
« Reply #10 on: 04 January 2011, 18:42 »
Well it's just sat on the shelf mate,so let me know,it was only taken off a couple of months ago when i id an engine change after the missus blew it up  :grin: so i know it works perfectly.
Will take some numbers off it in the morning for you to check.
Offline Bellend
« Reply #11 on: 05 January 2011, 18:32 »
Will let you know, cheers mate.
Dad got a TB today, went to turn the car round, went onto the road and it died. Rolled it down the hill, stripped it there and then and then found it was the wrong throttle body.  :rolleyes:
My fault, should have checked. It's off a 92 so therefore has less pins then the one I need. I swapped the top of it over though containing the injector.
No help.
Eventually got it going and it took 20mins going round quiet roads to get 20seconds up the road. Used an amazing amount of fuel.
Disconnect O2 sensor, no change. Changed temp sensor, no changed. No visible airleaks unless it has a massive manifold leak, not detected by spraying carb cleaner all around it.
What else can it be? Changed the fuel pump relay as there was a spare (working) in the car, no help. There was fuel in the pipes up top when I took them off. It's also using stupid amounts of fuel, so I'm positive the pump is OK.
What else can it be? Unless it really is something like the distributor or leads, but they are all sparking.
Timing is fine.
Have to get it returned and get another elsewhere.
Where all my moneys went.
« Reply #12 on: 05 January 2011, 19:20 »
Timing definatley isnt 180deg out?
Try doing a compression check(with throttle wide open) see what reading you get,these engines are prone for the headgasket going badly between pots 1 and 2 giving all sorts of weird problems.When it went on hers it made such a weird deep noise,i thought the airbox had fell off.
Im still swayed to the throttle body though mate.
« Reply #13 on: 05 January 2011, 21:12 »
Got some numbers off that dizzy for you mate.
Z415
0257 520 036
050 905 205 AH
£10 with a new Dizzy cap :grin:
Offline Bellend
« Reply #14 on: 05 January 2011, 21:45 »
Cheers for that mate.
Mentioned headgasket and apparently it overheated twice, once badly before trouble.  :rolleyes:
Nobody told me.
Proper weird one with the fuel suddenly going up, but the fuel pump is forcing a lot of pressure.
Engine is running PROPER deep, so deep you can take the air filter off and it makes no difference.
No airleaks, confirmed. Worried.
Just spent £200 insuring the poxy thing. BADLY need it next Friday onwards.
Gonna take home the headgasket testing tools, do a  compression test as you say and see what it brings up. If it is, I'll swap the insurance and tax over to my Golf and use that.
« Reply #15 on: 05 January 2011, 22:21 »
I thought it was a Golf we were talking about? :laugh:What engine code is it just out of interest?Ive got a good straight head here too if yours turns out to be buggered.£25 to you :grin:
I will get my garage empty if it kills me ha ha
Offline Bellend
« Reply #16 on: 05 January 2011, 22:35 »
Haha nice one. May well come and raid it.
I've got a 1.6MPi, sitting still cause insurance is stupid.
My dad's got the 1.8SPI we're having trouble with. Needs a car so if the h/g has gone, chuck the insurance and tax on mine.
Cheers though, see what tomorrow brings.
« Reply #17 on: 05 January 2011, 22:51 »
Cool,keep the thread updated,im interested to see what the problem is now :grin:
Offline Bellend
« Reply #18 on: 05 January 2011, 23:01 »
Will do. Was reading another thread, same problem, never did post the final result. So annoying.  :grin:
