Author Topic: LED rear lights  (Read 10155 times)
Offline SteveP
Re: LED rear lights
« Reply #20 on: 04 January 2011, 10:58 »
1x 5K0 945 093 Q (Inner Light)
1x 5K0 945 094 Q (Inner Light)
1x 5K0 945 095 L (Outer Light)
1x 5K0 945 096 L (Outer Light)
Offline MAW73
  • Used to like Golfs :-)
Re: LED rear lights
« Reply #21 on: 04 January 2011, 12:13 »
Thanks very much Steve.
The production date on my car was the 02/07/2010. Would this build date o.k. for the lights etc?
Martin
2014 BMW F20 M135i, Auto
Offline SteveP
Re: LED rear lights
« Reply #22 on: 04 January 2011, 12:19 »
The lights are the same for all Mk6's, just need to know what version of CEM you have to be able to 100% confirm.
« Last Edit: 04 January 2011, 12:22 by SteveP »
Offline SteveP
Re: LED rear lights
« Reply #23 on: 04 January 2011, 12:24 »
Would need to check the CCM version on the early 2009 cars.
SteveP
How does this look to you?
Thanks
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0360
   Revision: 00020000
   Coding: 48180A3A9825F1C044080080140001E441510088536D8D60648000000000
   Shop #: WSC 01357 011 00200
   VCID: EDDACE598DE3
I think that's the original version that doesn't support the LED's properly (i.e. you can't clear the bulb out warning on the dashboard).
I will double check and let you know.
Edit - Just confirmed with my old notes that is version of the controller won't support the LED's, so a new CCM is required, these cost around £200  :shocked:
« Last Edit: 04 January 2011, 12:32 by SteveP »
Offline MAW73
Re: LED rear lights
« Reply #24 on: 04 January 2011, 13:41 »
Thanks Steve, where do I find the CEM info?
Offline SteveP
Re: LED rear lights
« Reply #25 on: 04 January 2011, 13:47 »
VCDS / Vag Com scan
Offline Snoopy
  • Moderator
  • Geoff.
Re: LED rear lights
« Reply #26 on: 04 January 2011, 17:59 »
I thought all from build week 47 2009 on had the programable CEM?
Current Garage:
35+ years of GTI ownership.
Offline Wabbit
Re: LED rear lights
« Reply #27 on: 04 January 2011, 19:22 »
SteveP
Thanks for the info, even though it was not what I wanted to hear!!!
Is the part number any different for the later versions or is it the same ?
Thanks for help
Golf GTD MK6 Zenons, Leather, Dynamic Chasis Control, Park Assist, RNS510. Golf GTi Mk6 DSG, Leather. Golf Mk2 G60 Edition One, Recaro's, e/w, c/l, ABS
Offline R32UK
Re: LED rear lights
« Reply #28 on: 04 January 2011, 19:29 »
I am quite sure my car is early 2009 and no probs with LEDS
Offline Wabbit
Re: LED rear lights
« Reply #29 on: 04 January 2011, 19:39 »
What was the delivery date of your car? What coding did you use? Do you have vagcom?
I may give mine a go before I decide what to do.
