Author Topic: Windscreen wiper motor death and linkage seizure fix  (Read 7395 times)
Offline richw911
Re: Windscreen wiper motor
« Reply #10 on: 14 January 2011, 18:35 »
Right then...£230 saved by doing this, and it's easier than it seemed to just fix the siezed linkage and all now working...took some photos as I went along so will do walk through later  :smiley:
Ideal  :cool:
Offline dTEA
  • back in an MK5
« Reply #11 on: 16 January 2011, 21:56 »
Bugger...seems the motor has gone...was working now not! Strip back down and replace motor then :sad:
Edition 30 / T5 T32 Kombi
Offline richw911
« Reply #12 on: 16 January 2011, 21:57 »
 :sad:
Offline dTEA
  • back in an MK5
Re: Windscreen wiper motor death and linkage seizure fix
« Reply #13 on: 16 January 2011, 22:32 »
Well easy enough to strip the actual linkage and to free off.
Flip the caps off the windscreen wiper arms to get to the retaining nut. Undo the nut slightly but not full and lift the wiper arm off the screen and it should wiggle loose...then remove the nut.
remove the skuttle panel by going to the right hand side and unscrewing the smuggle over the pollen filter. Then lift the skuttle up from the windscreen edge and away. This can be a bidditch and the trick is to start at the corners...do not use anything against the screen ie screwdrivers as it is likely to crack.
Next remove the linkage, there are 3 retaining nuts with washers...worth checking the state of them at the same time. To get the motor connector off can be tricky as my wiring was quite short. Once disconnected then remove the whole linkage and motor.
Next it time to make note of the orientation of the linkage and motor arm...then remove the motor by dropping the couple of nuts/bolts off. Make note of the orientation of the linkage.
Then it's time to free the linkage off...i then had to rmove the spindles from the linkage. Mine weren't too bad. C clip wanted to fly off tho and was a bugger to find :grin: Once out I thoroughly greased them and reversed the whole process.
I found it easier to replace the skuttle by removing the end caps around the bonnet/A pillar also a bit of silcone based lube may help
Offline dTEA
  • back in an MK5
« Reply #14 on: 16 January 2011, 22:33 »
Forgot to say that this is also useful for replacing the linkage when the spindles are worn for the wiper arms
