Author Topic: Accuair Elevel Mk1 golf 20v turbo  (Read 534284 times)
Offline travisreeve
Re: mk1 golf 20v turbo GYD
« Reply #890 on: 05 April 2012, 17:42 »
Cheers guys realy appreciate it :D
Today i recived my qpeng FINALY :P
Offline DanChave
« Reply #891 on: 05 April 2012, 19:19 »
Sweet!!!
Offline travisreeve
« Reply #892 on: 05 April 2012, 21:33 »
Thats the loom in.. Just have to mount the ecu and fuel pump relays then connect the live and earth and booom done :) easy simple bit of kit
Offline travisreeve
« Reply #893 on: 07 April 2012, 18:28 »
Mounted my ecu and fuel pump relays.. Only temporary tho..
Bought a shallow sump from awsome gti
And im now hooking up a deal for an air ride kit
Its all go now aha
Offline travisreeve
Re: Stance solution mk1 golf 20vt
« Reply #894 on: 09 April 2012, 20:27 »
Okay the low down  :wink: on air
Iv bought a kit from 'stance solutions' the kit is for the front only. Its 2 cylinders that fit onto the coilovers and gives you a 50mm clearence. So now il be able to drive the car how it should be driven then when im at stand still have it aired out for some major stance  :grin:
Offline murraymint
« Reply #895 on: 09 April 2012, 20:28 »
How much was that kit if you don't mind me asking? Sounds ideal
josh
Offline travisreeve
« Reply #896 on: 09 April 2012, 20:39 »
Sorry didnt post a pic aha
£375+postage.. Doesent use a tank just fills up straight of the compressor, if you do it that way the raise time is 10 seconds.. If you fit a tank and a better compressor raise time is 2 seconds, this is what il be doing
Offline DanChave
« Reply #897 on: 09 April 2012, 22:21 »
This air business sounds awesome! Can you get kits for the front and back?
Offline Toby
  • Car - less
« Reply #898 on: 09 April 2012, 22:31 »
Looking sweet so far!
Are you tidying up the engine or leving it like that?  :undecided:
Currently down under
Offline travisreeve
« Reply #899 on: 09 April 2012, 23:35 »
Just fronts dan  :smiley: il run the rear slammed or as best as i can and the kit for the front is so i can use the mk1 how i want to and have it look how i want ;)
Toby iv left the engine and gearbox like that as it might not be any good as yet aha i know i shouldnt say that but id be so pissed if i cleaned it all up realy nice and i have to bin it aha il pull engine out over crimbo and clean it all up as i wanna tuck my loom and smooth my bay
