Author Topic: New starter motor/ alternator  (Read 1636 times)
Offline walchy01
« on: 27 December 2010, 19:07 »
Evening all
Looking at spending even more cash on the girl :laugh:
Anyone know how much a new starter motor and alternator will put me back, and if they are still available at VW or even TPS...
Thank you
Offline Adam
Re: New starter motor/ alternator
« Reply #1 on: 27 December 2010, 19:47 »
Going on EuroCarPart
Starter - £121
Alternator - £133
And using promo code box20 you get 20% off your order until the 6th.
Down Hill From Here.
Offline walchy01
« Reply #2 on: 27 December 2010, 20:31 »
Are they both Bosch parts???
 Thanks for that.....
 :wink:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #3 on: 27 December 2010, 22:18 »
Are you sure that the alternator is knackered?
9 times out of 10 you just need to replace the voltage regulator if it fails or the brushes are worn.
Offline sparks03
  • Look at the veins in that
« Reply #4 on: 28 December 2010, 00:00 »
Think GSF stock Bosch starter motors from around £80, better than the ECP 20% off  :smiley:
http://secure.gsfcarparts.com/shop/results.asp
 correction- £82-£86
« Last Edit: 28 December 2010, 00:13 by sparks03 »
<br />   Heaven is 13 feet long
Offline walchy01
« Reply #5 on: 28 December 2010, 07:35 »
TBH nor 100% certain where the fault lies, but just getting some ideas and price guilds so I can sort it asap, don't like her sitting there doing nothing even thou it is a second car, please see my other post asking for ideas to the problem posted yesterday... Thank you
Offline dan_apps
  • too low for british roads!
« Reply #6 on: 28 December 2010, 09:50 »
dont be spending that much ffs! as said are you sure this is the problem, scrappy trip for starter for sure!
Offline dadrathers
« Reply #7 on: 28 December 2010, 21:36 »
New alternator from GSF Bosch around 50 incl VAT - starter motor GSF Bosch 91 incl VAT (at 15%) - both on 'exchange'.
Don't forget to get a new bush for the starter motor where it fits into the gear box housing - I think GSF ones come with it. You should replace the alternater belt whilst you are at it as well.
Hope the weather is good for you when you do the job, -10 degrees is not pleasant!!!
