Author Topic: winter tyres  (Read 42354 times)
Offline Bellend
Re: winter tyres
« Reply #150 on: 13 January 2012, 19:07 »
Got some winter tyres fitted today. Brand new 195/45/15. Replacing the 205/50/15's. Ride is far more firm but feels more comfortable somehow.
They are Nankang Ultrasport II. Ditchfinders is all I've heard about Nankangs but these "M+S" tyres are fantasitc! SO MUCH more grip over the Toyo-T1R in the freezing cold. Awesome grip so far and for the price for some snow tyres, sweet.  :cool:
Deffo see the advantage.
Where all my moneys went.
Offline mcgee9t2
Re: winter tyres
« Reply #151 on: 13 January 2012, 19:12 »
im thinking about taking mine off soon. no sign on snow, only had to defrost my car once this "winter"
Offline Bellend
Re: winter tyres
« Reply #152 on: 13 January 2012, 20:25 »
They grip better in the cold.
Offline Jay
  • balding fat cvnt
Re: winter tyres
« Reply #153 on: 13 January 2012, 20:45 »
Cold? What cold?  :huh: it's been spring since the end of Autumn with a cool draft now and then  :grin:
Offline Khare
  • The bear that khares
Re: winter tyres
« Reply #154 on: 14 January 2012, 12:11 »
Agreed. Last night on my way out from work was the second time this winter that I've had to scrape a thin layer of frost off the windscreen. It's been between 7-12 degrees here in the day since November sort of time. The way this is going summer should be epicly hot!
Offline Bellend
Re: winter tyres
« Reply #155 on: 14 January 2012, 13:38 »
-1 round here.
gixer1400
Re: winter tyres
« Reply #156 on: 14 January 2012, 16:54 »
only problem with the size of tyre is that they are 5% smaller than your 205's and will run 921 rpm against 874 rpm ... revs per mile ...use more fuel and the speedo will be out too  :rolleyes:
the tyre seller should have advised you of this  :undecided:
Offline Bellend
Re: winter tyres
« Reply #157 on: 14 January 2012, 18:19 »
So far, I've found the car more lively and using less fuel on the rural roads, less effort to pull away.  :wink:
Also, speedo is actually more accurate.  :smiley: Speedo now says 29 at 30.
Was a mate in another garage. They're fine. :)
Offline danny_p
Re: winter tyres
« Reply #158 on: 15 January 2012, 00:55 »
my opinions on winter tyers ect
winter tyers are highly overated IMO   Good quality normal tyers are pritty bloody good,  no point getting winter tyers the same size as they'll be to fat.
cold wet weather demands narrow tyers  they cut through standing water better ( you meet much more of that than snow )  and they cut into snow better.
i've never botherd with superfandango snow tyers,   if the conditions are bad enough to make it worth swaping tyers over wrap them in chain.
  i went down from a 205/55/16 to 165/75/r15 el cheepos and fitted 9mm chains.  did over 1000 miles on them, chains ate the tyers a bit hence useiig cheep ones but grip was awsome comaperd to anything but studed tyers
all the VW's have gone bar 1.
Offline Ess_Three
Re: winter tyres
« Reply #159 on: 15 January 2012, 01:21 »
And I'll counter with a few points:
Quote
Really?
so the whole of the motoring world are incorrect in seeing the benefits?
Normal tyres are crap under 8 degrees C. I've had winter tyres on my last 3 cars...and without them, you can't pull out of the driveway.
Oh, and my winter tyres are the same width as my 'normal' or summer tyres...I've tried 195, 205 and 225 wide.
Currenty run 225/40/18s on the Golf and I can go where people in X5s etc can't.
Too wide you say?
It appears not...
Quote
Wrong.
Cold weather demands a compound and tread pattern designed to cope with low temperatures.
My winter tyres are as good in warm standing water as my summers, vastly superior in cold standing water...and in a different league in slush and snow.
Cutting into the snow/slush is about the tread pattern biting into the snow then shedding the compacted snow as it spins....explain again why a narrow tyre does this better than a wider one?
Quote
I can't get chains onto my Mk6 GTI..and arsed with stopping every 1/2 mile to take them off/put them on again...when I can stick winter tyres on (properly speed rated) and drive through 8" of snow one minute, then do 155 MPH on the Autobahn the next without the need to get out of the car.
So winter tyres...let me drive anywhere I want to go in pretty much any weather, where not fitting them means I can't get out of the driveway.
I didn't have any winter tyres for the winter of 2005/2006...and I couldn't get out of the driveway.
If you live where the weather is bad enough to justify them...you will NEVER go back after using them.
The benefits are huge.
Underrated, in fact...
..but gaining motorcycles.
