Author Topic: Help Please - Engine cut out  (Read 2296 times)
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: Help Please - Engine cut out
« Reply #10 on: 23 December 2010, 17:34 »
this is very rare on mk3s
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline GCGTI
« Reply #11 on: 23 December 2010, 18:54 »
Thanks for all the input. I am very grateful to you all. I am also amazed at how common this seems to be, page after page can be found on this topic and unfortunately there does not seem to be a definitive solution, therefore if you read this post and have anything to add please do.
Offline Khare
  • The bear that khares
« Reply #12 on: 23 December 2010, 18:59 »
Because everyone's engines are in different conditions. Where as one may have bad wiring other may have dampness and another may have just wear and tear.
As I said, coil is a common part that fails on the golfs.
« Reply #13 on: 24 December 2010, 09:06 »
what engine code is it? if you're unsure, does it have an ISV?
Offline Sii
« Reply #14 on: 24 December 2010, 11:40 »
My best guess would be in this order:
Crank position sensor
ECU relay #30
Fuel pump relay #167
Coil pack
Dirty throttle body (although would likley start up again when tried)
There are pages and pages of 'cutting out' threads and if it's electrical it can be difficult to trace as some faults only show on VAGCOM when they occur and are not stored in the memory. Just had my crank position sensor replaced and all sorted now.
Best of luck!  :smiley:
Offline GCGTI
« Reply #15 on: 10 January 2011, 20:36 »
 :cry: :cry:Still not got my pride back on the road, replaced the ecu relay and the fuel pump relay no good. Got it towed to a garage  :angry: and they have told me there is no spark at the plugs or the dizzy and that they think it is the dizzy. They want to remove it and test it? they have quoted me a staggering £250 to replace it plus labour, Eurocar parts list one for £75.... not f@@king impressed!!!
Reading some of your informed threads it seems to me that if there is no spark at the dizzy you guys suggest it is the coil pack can anyone confirm this thinking??
Eurocar parts has the coil pack for £35 so i guess the garage will quote me about £150!!!!! :angry:
Offline javalin
« Reply #16 on: 10 January 2011, 21:23 »
no spark is one of at least two things; a bad coil or the ECU not realising it should be triggering the coil.  The crank/cam sensors tell the ECU when to spark - i.e. you could have everything else 100% but if the ECU doesn't see the signal - it won't trigger a spark.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #17 on: 11 January 2011, 09:58 »
does it have an isv? if not, its agg/ady and the problem is likely to be the crank sensor or the coil. its not the dizzy, you can unplug the hall sensor completly and it'll still run!
if its got an isv the code is 2e and it doesnt have a crank sensor, so in that case it'll be dizzy or coil
Offline GCGTI
Help Please - Engine working !! Wheels not so good.......
« Reply #18 on: 24 January 2011, 17:12 »
 :smiley: :smiley: :smiley: Finally back on the road. Sourced a second hand Dizzy with ht leads, dizzy cap and rota arm on ebay for £17 shipped :smiley: :smiley: Garage fitted it for me and we are back in business!!
On with the next job/s now, noisy wheel bearing and front wheels dont seem to be lined up????? ie position in the arch is not the same, nearside seems further out of the arch than the offside  :undecided: any opinions / help welcome.
