Author Topic: Big Turbo Matters  (Read 4586 times)
Offline AaronGS
Re: Big Turbo Matters
« Reply #20 on: 20 December 2010, 18:29 »
there was a feeler for sale thread for a gearbox with LSD a few weeks back, I think on Seatcupra.net...
Offline Purely VAG
« Reply #21 on: 20 December 2010, 22:19 »
Fair point, Can't beat 4WD though but keeping this shell would save me alot of hassle.
Thing is i need to run 6 speed with 350bhp, Even now its feel stressful sitting at high revs all time.
Im contemplating just fitted SMF flywheel, paddle clutch and using a PD130/150 gearbox.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline AaronGS
« Reply #22 on: 21 December 2010, 09:26 »
Why do you think you need 6 speed with 350bhp? I run that power and the 5 speed is great. Dean at Awesome used to run the same power but through an anni 6speed and said it was a nightmare and believes mine is much easier to drive. Getting through the gears on a 6speed is not gonna be fun, sometimes I wish mine were longer. just put an LSD in yours and away you go till you find a 4mo shell!
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #23 on: 21 December 2010, 10:43 »
Jord - after speaking with Nick a few months back sounds like the diesel box is a good idea. think he said he had seen one that was on a 1.8t and was easily getting 110-120mph in 3rd gear
Offline Purely VAG
« Reply #24 on: 21 December 2010, 12:15 »
Aaron, The ratios too low on a 5 speed, Setting off with 6 speed diesel box is like setting off in 2nd on 5 speed. Means i wont be spinning up and final drive is much much longer. Theres a vortex thread listing ratios
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #25 on: 21 December 2010, 12:23 »
is it gona be easy mating the 6spd up to a 5spd engine ?? i no most people say its too much hastle to change from 5spd to 6spd is it really that bad ??
Offline tg1
« Reply #26 on: 21 December 2010, 12:35 »
i doubt its thaat hard, but if i was to do it, all it would involve was a phone call to my mechanic and some money  :laugh:
Offline AaronGS
« Reply #27 on: 21 December 2010, 16:36 »
Ah, didn't catch the diesel bit! Fair enough, will be interesting to see how easy it is to do and how it works. Longer final drive will be good.
I do not spin up unless its very wet but even then it is controllable if you don't just floor it!
Offline Purely VAG
« Reply #28 on: 21 December 2010, 21:14 »
Going to try the diesel box on it, if that doesnt suit ill hunt a 4mo shell.
6 speed box mates straight up, Change selector, shafts, starter. Adapt hydro line, sorted.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #29 on: 21 December 2010, 21:16 »
i no its not about your thread how much including box would you charge for the swap ??
