Author Topic: Reverse Camera & RNS510 Question  (Read 9171 times)
Offline iggis
Re: Reverse Camera & RNS510 Question
« Reply #10 on: 02 January 2011, 16:48 »
No. You then have to tell the car you have the navigation unit for it to talk to that (MFSW buttons and Nav on MFD) and tell the RNS510 you have the camera unit.
I went from the RCD to the RNS thinking it would just be a plug and play job but the car needs told basically  :laugh:
The nav on the MFD is very impressive once coded.
Has anyone got a full coding list for the RCD to the RNS upgrade on the MK6? Would be helpful to anyone thinking of doing this to get the MFSW/MFD/camera working or does the thread by p3eps cover it all?
Offline p3asa
« Reply #11 on: 02 January 2011, 16:50 »
p3eps post covers it all.  You only have to tell the car you have NAV and the rear camera.
Offline iggis
« Reply #12 on: 02 January 2011, 18:17 »
Thats great. thanks.
Offline mortygt140
« Reply #13 on: 03 January 2011, 16:52 »
Iggis the car doesn't know you have the rear camera,  the golf camera system is not like the one on other vw models i.e Passat/Pas CC, Touareg, Tiguan. The golf is just an AV feed to view video...Whereas the Passat uses a dedicated camera module and needs the Camera Module 6C ticked in the CAN Gateway.
Once you fit the RNS510 its only coding in the RNS to let it know the camera is there and to open the AV channel to the camera once reverse is selected.
Darren
Offline iggis
« Reply #14 on: 03 January 2011, 17:20 »
Darren
Thanks Darren, I am surprised it cant be done through the RNS setup if it is only an AV feed. I will try through VCDS tomorrow.
Ian
Offline iggis
« Reply #15 on: 04 January 2011, 13:09 »
Ok, sucess. Well, partly. I have got the rear camera working, but not the MFD (navi instructions) or the MFSW (<> buttons). I selected the shortpress steering wheel option and deselected BAP. Also all my button lights have turned red (instead of white).
Any ideas? Golf MK6 with RNS510
cheers,
Ian
Offline SteveP
« Reply #16 on: 04 January 2011, 13:49 »
You need Bap enabled for a Mk6.
Also what buttons do you mean are red instead of white?
Offline iggis
« Reply #17 on: 04 January 2011, 15:34 »
thanks Steve, BAP enabled sorted it. Note that I had to do a soft reset on the RNS to get it to work, (<>+i). The buttons I mean are everything that is backlit on the doors and dash.
cheers,
Ian
Offline p3asa
« Reply #18 on: 04 January 2011, 15:37 »
They are meant to be red are they not?  So yours were white and then changed to red?
Offline iggis
« Reply #19 on: 04 January 2011, 15:57 »
Yes, unless, I'm having a senior moment lol
