Author Topic: 1.8T AGU no boost, lost all power  (Read 22093 times)
Offline the40ftpenguin
Re: 1.8T AGU no boost, lost all power
« Reply #10 on: 17 December 2010, 04:42 »
dunno if uve fitted it yet but i had a very similar problem in mine, i take it when u unplugged ur MAF ur car refused to run as mine did...which is normal as for some reason most if not all AGU engines wont start once the MAF is unplugged unlike other cars which will simply run on a default factory setting..my MAF was the cause of a month or two of tinkering which finally ended in what i should of had checked more thoroughly...if u go to ebay u can pick a new one up for about 40 quid ish...just dont get ripped off as theres a tonne of people advertising the correct fitting MAF and they send you a different one...i got mine from a place called Europarts for 60 quid brand new...with the aid of a pack of security bits my power issues were solved! ill see if i can find a link to my old post with my description on it of what my problem was see if its anything like yours
1.8 20v Turbo
AGU
« Reply #11 on: 17 December 2010, 04:45 »
http://www.golfgtiforum.co.uk/index.php?topic=166128.msg1539688#msg1539688 as promised lol...thats pretty much what was going on with mine when the MAF was dodgy...intermittent fault...but it ran like a dog when it was on an off day
1.8 20v Turbo
AGU
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 17 December 2010, 08:51 »
The car should run on basic fuel/air settings with the MAF unplugged even on an AGU. I know mine does. I would say there is a problem if it doesn't
« Reply #13 on: 17 December 2010, 12:16 »
nah mine doesnt, its not an issue just a problem with certain MAF types etc im told...some just refuse to start outright with it unplugged =\ i could be wrong however lol
1.8 20v Turbo
AGU
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #14 on: 17 December 2010, 12:31 »
Get a genuine exchange MAF from TPS. Dont bother with ebay reps as people have had alot of problems with them.
Offline sonyboy
« Reply #15 on: 23 December 2010, 18:06 »
Sorry guyz problem not solved ;)
I have the same problem like before, i fix that wire on N75 valve and it ran fine fews days.
But this morning again no turbo, i look at errors over vagcom, but there is no errors at all.
Few days ago i had strong turbo spool and achieve 170 km/h uphill, this morning couldnt reached 100 km/h up hill. Same problem no turbo sound, no power from 1K to 3K, after 3K it ran good to 4.5K but not a bit like before, same problem. no idea.
Even i changed all vac lines from inlet to FPR and line to metal pipe from DV valve.
Lambda is fine from -4 to +7%, not bad for now.
I have no idea, i'll try change MAF and ordered Ignition Amp.
Offline sonyboy
« Reply #16 on: 30 December 2010, 17:59 »
Changed MAF, put brand new OEM. Two days it was running good, very smooth, no cold start misfire or so, and today i've lost half o my boost. suddenly i just feal that gas pedal is not under pressure, and i hit it to the floor and i got same situation like before, car was dead until 3K, and then there is 30 40% of boost. i can hear turbo but no max boost,
also i notice there is strange shake of engine at idle.  car is shaking like mad but revs where constant at board no change?
i bought ignition amp i'm going to change it right now.
new maf did not solve the problem, but it is running better when cold very smooth during drive and after cold start.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 30 December 2010, 19:41 »
air leak? tried all the pipes including the one under the inlet manifold?
Offline sonyboy
« Reply #18 on: 30 December 2010, 21:08 »
few minutes ago i changed the ignition amplifier, no improvement. As I notice when i start the car and temp was aroun 2C, ca ran very good and there was strong sound from turbo of sucking air etc., as more as i drive it it getting worse.
even pipe between inlet manifold and PCV valve of breathing system is new. I checked air leak with air compressor no shhhhh sound no leaks, even changed vac line for FPR and DV valve.
everything is changed maf, ign. amp, g62 cooland sens, n75 tried J, DV tried 710n, vac lines, test leak, cleaned IAT sensor, pcv valve checked, connectins to sensors checked, wastegate is moving, turbo is running great when it is running there is strong suck of air.
Only what could be is lambda snesor, it is only one that is not changed. so is it possible when lambda is warming and warming that is getting worse for perfomanse. i have good readings from lambda at idle and running.
two pipes i dinot checked, that is from n75 to wastegate, and some kind from turbo to oil breathing system or pcv system ?
any new ideas???
Offline will gti
  • ARZ 1.8T
« Reply #19 on: 31 December 2010, 11:34 »
sounds like you no your stuff mate but have you thought about taking it to a garage....you must of spent hundreds  :sick:
WHEELS IN SIG FOR SALE FERB'D WITH NO CURBING, ALL WITH GOOD TYRES GOODYEAR NCT 5
