Author Topic: suspension needs doing  (Read 2589 times)
Offline Ben Lessani
Re: suspension needs doing
« Reply #10 on: 16 December 2010, 10:01 »
on some struts, they are 2 parts. A housing and insert. The shock being a little tube that threads into the housing.
Some are sealed, which means the housing and insert is 1 piece.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #11 on: 16 December 2010, 10:06 »
There we go. Having only bought and fitted 2 lots of shocks then obviously mine were sealed.  Hence the silly question.
Well you learn something new every day.
Thanks.
« Reply #12 on: 16 December 2010, 11:00 »
BUT I would not fit the front ones again... The inserts are CR4P.... Buy OEM G60 struts whilst you can... Not that much dearer
What makes you say they are crap, I have never had any issues with inserts, main thing is to put a tiny amount of used engine oil in the housing first as it stops the insert rattling around.
