Author Topic: HELP NEEDED changing interior door handles!  (Read 1970 times)
Offline jiminbmth
  • brings back the sunshine!
« on: 11 December 2010, 10:43 »
JUST THOUGHT I WOULD ASK BEFORE TEMPTING TO CHANGE OVER MY OLD BLACK PLASTIC ONES FOR SOME NICE SOLID METAL CHROMES,I DONT WANT TO DESTROY ANY CLIPS/FIXINGS!
ANYONE POSTED AN VIDS ON THIS? HOW EASY IS IT GUNNA B?
jiminbmth ;)
Offline jeynesey
  • Non VW but still VAG
Re: HELP NEEDED changing interior door handles!
« Reply #1 on: 11 December 2010, 12:56 »
Ill be there, convoy anyone?
Offline Seanl
« Reply #2 on: 11 December 2010, 15:14 »
Just did the same to mine last week. Really easy actually. Take your door cards off by removing the outer bit of the grab handle, and removing the 2 screws. Take off the card by levering something in the side (being carefull with the paintwork) and pop off the retaining clips all around. Unplug elec window switch, elec mirror switch, and speaker. Once removed, you will be able to see exactly how it needs to be done. Take off the catch release cable thingy and then you just pull the handle towards you, which lines up the flat edge on the pivot, and just pull out. Have a look on the new ones to see what I mean about where they pivot. Fitting as they say, is the reverse. Hope this sort of helps!
Offline jiminbmth
« Reply #3 on: 12 December 2010, 02:41 »
       javascript:void(0);                            Cheers........or as my daughter says......THATS SICK THAT IS!! :laugh: :sick:
jiminbmth ;)
