Author Topic: Weird knocking  (Read 4555 times)
Offline The Mighty Elvi
  • I'm better than you today.
Re: Weird knocking
« Reply #10 on: 10 December 2010, 16:12 »
I have someting similar.
Its a loud rhumble from both wheels, but strangely it disappears when turning the steering wheel a few degrees and when i go over bumps in the road at speed.
Is that my CV joints and/or wheel bearings?
Offline Ben Lessani
Re: Weird knocking
« Reply #11 on: 10 December 2010, 16:14 »
Quote from: Meeeeeeeeeeeeeeeeee
Knocking at the front could be a few things. Make sure the suspension strut bolts are tight, all 4 ball joint bolts, wheel nuts and hub nut.
Track rod ends
When you hear a knock when wiggling the steering wheel when stationary. If the car is jacked up, its not as obvious to find.
Wheel bearing
Turn a corner at speed (40 mph), if you are turning left and you hear a noise - its the right wheel bearing, turning right and its your left wheel bearing.
Jack the car up, grab it left and right and wiggle it and check for play. If there's play and a noise as above, odds are its a wheel bearing.
Ball Joint
Grab the wheel top and bottom and wiggle, have a friend with a torch look at the ball joint when wiggling and the play is pretty obvious.
CV Joint
Knocking/grinding at low speeds
Top Mounts
No idea, I guess I'd find out by process of elimination from the above?
Offline apie2004
Re: Weird knocking
« Reply #12 on: 10 December 2010, 16:41 »
could be engibne mounts if it happens under braking/acceleration
I thought that but I renewed them fairly recently (about 4k ago)
Offline lemski
  • 16v
Re: Weird knocking
« Reply #13 on: 11 December 2010, 17:05 »
Mine does it but its a wishbone bush on mine.
Offline apie2004
Re: Weird knocking
« Reply #14 on: 12 December 2010, 01:10 »
Had a go at changing the wishbones today and I tried undoing the bolt furthest back on the wishbone and it just spins? Is there a nut on the chassis thats broken/ do I have to put something on the other end of the bolt, where is it?
J
Offline messenjah
Re: Weird knocking
« Reply #15 on: 12 December 2010, 02:40 »
check your wheel nuts !!!!
Offline danny_p
Re: Weird knocking
« Reply #16 on: 12 December 2010, 03:04 »
J
unluck the captive nut has broken free    there is cutting and welding involved in fixing that
all the VW's have gone bar 1.
Offline lemski
  • 16v
Re: Weird knocking
« Reply #17 on: 12 December 2010, 08:11 »
The wishbone attatches to the subframe? There's 2 bolts with nuts on the end
Offline apie2004
Re: Weird knocking
« Reply #18 on: 12 December 2010, 12:08 »
J
Excellent
