Author Topic: New Battery help - UPDATED with Pics as well.  (Read 6754 times)
Offline The Mighty Elvi
  • I'm better than you today.
Re: New Battery help - UPDATED with Pics as well.
« Reply #20 on: 14 December 2010, 15:02 »
What do you mean by double the earth?
Put in an additional cable?
Offline clipperjay
« Reply #21 on: 14 December 2010, 15:04 »
Yes the cable on the negative terminal goes down to the block you can trace it then double it up right to the gear box bolts, there should be at least two or three bolts just looking right down there!
The idea is the ground or earth has maximium grounding all around the car chassis to help make better connections with the circuit!
« Reply #22 on: 14 December 2010, 15:07 »
Ta verymuch.
will do.
Jonathan.
