Author Topic: oil catch tank install  (Read 2920 times)
Offline 2001gti4
Re: oil catch tank install
« Reply #10 on: 10 December 2010, 11:46 »
Same as anything, the more you pay the higher the quality you expect. I just didn't see the point paying 3-4 times as much for something if the cheaper one does the job.
Each to their own  :smiley:
My Golf is dead but at least I have this....
Offline rio_gti
« Reply #11 on: 13 December 2010, 14:56 »
cheers for ya replys will be orderin it up soon for the new year.
tech1889 youll have to let me know how to fit it as you've done a banging job at yours i've just forgot a bit where and how  :smiley:
Offline 2001gti4
« Reply #12 on: 13 December 2010, 16:25 »
Fitting's not too difficult:
Catch can on battery housing
Fit new breather pipe and o ring
Connect breather pipe to bottom of T piece with 19mm hose, connect suction pump to one side of T piece with 19mm hose, connect other side of T piece to catch can port with 19mm hose (and 15mm hose & downsizer if using 15mm ports on can)
Remove Y pipe and connect TIP to other can port (using 15mm hose and downsizer if using 15 mm ports on can)
You can't go wrong with this guide http://uk-mkvs.net/forums/t/269734.aspx?PageIndex=1
