Author Topic: Golf window+minus temp= broken runner!!  (Read 1826 times)
Offline mr 1.8t dubbster
Re: Golf window+minus temp= broken runner!!
« Reply #10 on: 13 December 2010, 17:34 »
well all i needed was the white plastic clip to till i unscrewed the motor off the metal sheet behind the doorcard, you can buy the cable as a set which comes with cable ties which wraps around the motor, then snipping the tie off so it locks under tention, i just decieded to get the garage to do it as if i mess it up its really tricky to put back together.
Forge Splitter, Smothed Airbox, Re-map and coilovers next.
