Author Topic: Handbrake cable replacement  (Read 11614 times)
Offline the_stink
  • A3 140 TDI
Re: Handbrake cable replacement
« Reply #20 on: 09 December 2010, 08:16 »
well i have owned the mkii for 6/7 months now so far:
*New throttel cable
*New Starter Motor
*New Bonnet
*New Slam Pannel
*New Headlights
*New Spotlights
*New Front Bumper
*New wheels
*Replacement Rear bumper (currently sat in my room )
*Replacement Tailgate (currently sat in my room )
*Replacement MFA stalk (currently sat in my room )
*Replacement PAS Pump (currently sat in my room )
Still need:
*New expansion tank
*Front top mounts
*New Rear Driverside wheel bearing
Offline Ben Lessani
« Reply #21 on: 09 December 2010, 08:21 »
Whilst I've had my Golf ...
£12 - Clutch Cable
£41 - Alarm/Immobiliser
£7   - Haynes Manual
£4   - Windmirror Gromets and Handles
£20 - New heater fan
£22 - 4awg Wiring Kit
£38 - Sunroof Seal
£6   - Condensation/Water Trap
£18 - Bonnet Lifters
£17 - Leather Handbrake Gaitor
£12 - Smooth MK3 Door Handles
£13 - Inner Boot Cover
£25 - Debadged Grill
£30 - MOT
£30 - Rear Discs
£5   - Rear Bearing
£12 - 5l Quantum Semi Synth Oil
£6   - Big bag of 4awg and 8 awg Crimps
£1   - BatAid Battery Restorer
£4   - Rain X AntiFog
£4   - Duct Tape
£20 - HT Leads
£10 - Plastic Underbonnet Scuttle
£25 - Fuel Pump
£13 - Accelerator Cable
£60 - Sound Deadening
£10 - ARB Bush
£5   - Seat Covers
£20 - Front and Rear Lights
£35 - Electric Windows
£5   - Ring 80w/100w Rally Bulbs
£10 - Front Door Speakers
£40 - Fuel Line
£10 - Uprated Headlight Loom
£12 - Door Cards
£225- Coilover Suspension
£170- Creme Leather Interior
£200- Chrome 15" 7J Alloy Wheels
£130- 4x Uniroyal Rainsport 195/45/15
£5  -  Exhaust Clamp
£1  -  Exhaust Sealant
£10 - Steel Cable Ties
£25 - Full Stainless Steel Exhaust
£50 - Power Steering Setup
£40 - Gearbox
£25 - Sunroof Parts
£3  - Rubber Rocker Cover Grommet
£22 - 4 Gallons 10W40 Oil
£3   - Oil Filter
£5   - Ball joint lock plate
£2   - Manifold studs and nuts
£7   - PAS Belt and Fluid
£10 - PAS, Water pump Pulleys, HT Leads
£5   - Bottom Ball Joint
£30 - Battery
£15 - Wiper Mechanism
£30 - MOT
£15 - Wheel Alignment
£1  - Wire Wool
£12 - 6" Farecla Compound Pad
£5  - Farecla Paint Repait Kit  (used it for my alloys)
£40 - 4 Wheel Alignment
£20 - Metal Coolant Pipe
£40 - Radiator
£35 - Heater Matrix
£5  - Coolant
£20 - Heater box housing, Sunroof panel, Passenger door handle, Rear seatbelt, Glovebox, Interior boot trim, PAS bracket, Weighted shift rod, 99 Relay
£24 - 2x Front wheel bearing kit
£8 - Ball joint
£18 - 2x PAS Steering arm gaiter
£5  - Spark plugs
£10 - Forté engine flush
£30 - 25l 10w40 Engine oil
£5  - Rear top mounts
£5  - ARB bush kit
£25 - 4 Wheel alignment
£50 - Front pair grooved and vented Brembo disks
£20 - Front pair Pagid fast road pads
£25 - 8 New tappets
£11 - 8 Valve stem seals
£5  - 1L ATF
£10 - Rubber sump gasket
£8  - Rocker cover gasket
£4  - Oil filter
£3  - LEDs for Dashboard
£45 - VDO Gauges
£35 - Braided brake lines
£30 - MK4 callipers
£13 - 5l Fuchs XTR Oil
£3   - Oil filter
£10 - Thermostat housing (genuine)
£15 - 5 litres concentrated coolant
£20 - Drivers wishbone
£12 - Gearbox engine mount
£1   - Wishbone rear bolt sleeve
£100 - New windscreen
£12 - Rear top mounts
£8   - Tappet
£22 - Valve stem seals
£11 - Timing Belt
£16 - 2x Front flexi hoses
£18 - Rear engine mount
£25 - MOT
£40 - Front engine mount
£35 - Bosch coil
£80 - Bosch distributor
£30 - Rear beam poly bushes (Poly Sport)
£35 - Front op mounts (Lemforder)
£15 - 5l Car lube Dot4 brake fluid
