Author Topic: Big Changes  (Read 34215 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #60 on: 01 January 2011, 17:15 »
whats it gona drive like Ad ??
Offline Grand Master Patch
Re: Big Changes
« Reply #61 on: 01 January 2011, 17:18 »
The same as coilies,no difference.
With the two way systems air can be pushed from one bag to another when cornering,but with the four way set up,each bag has an independent air supply so can't be moved around while cornering.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #62 on: 01 January 2011, 17:19 »
so its gona be pretty firm then lol
Re: Big Changes
« Reply #63 on: 01 January 2011, 17:21 »
The barmy thing is no,the lower you go the comfier it will be :wink:
When raised right up the ride will be rock hard.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #64 on: 01 January 2011, 17:37 »
I take it because theres less air in the bags so more movement.. didnt tihnk of it like that so they are more practical than i once thought ??
Re: Big Changes
« Reply #65 on: 01 January 2011, 17:51 »
Correct.
It'll be the most practical mod i ever do to my car.
I can ride around as low as i like,then if i come across a road full of speed bumps or a multi-story car park etc.....a quick press of the switches will raise me up to clear them.It's also good if your carrying a few passengers and the tyres scrub,just add more pressure to raise it back up again :wink:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #66 on: 01 January 2011, 18:04 »
might mention this 'practical' mod to the other half lool..
Out of curiosity how long does your tank take to refill ??
Re: Big Changes
« Reply #67 on: 01 January 2011, 18:08 »
It'll take a few minutes if completely empty,but that doesn't happen very often.There is a pressure sender on the tank which will keep the tank at 150psi,if you raise and lower a few times this will lower the pressure in the tank and the compressor will kick in to top it back up to 150psi.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #68 on: 01 January 2011, 18:09 »
oh right cool.. Is there many common faults with air leaky bags or such ??
Re: Big Changes
« Reply #69 on: 01 January 2011, 18:12 »
A little leakage overnight is expected,but we're only talking a few psi.
It also doubles as a security device,if you drop it down at night both your car and wheels are going nowhere :wink:
