Author Topic: Big Changes  (Read 34150 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Big Changes
« Reply #100 on: 05 January 2011, 09:35 »
Patch's car had major gravel rash on the front end when i last saw it.
Offline Grand Master Patch
Re: Big Changes
« Reply #101 on: 05 January 2011, 21:05 »
Your not wrong :grin:
Re: Big Changes
« Reply #102 on: 06 February 2011, 22:24 »
Updates :smiley:
Stripped it all out.
Wired to test for leaks.
Installed in it's final position.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #103 on: 06 February 2011, 22:27 »
looks like top work mate is this all going to be boxed in or ??
Is someone a happy boy its finally all happening ??
Re: Big Changes
« Reply #104 on: 06 February 2011, 22:32 »
Time consuming,it's the longest we've ever spent fitting air but everything has been done as it should,no cutting corners on this one.Two days work so far,but we now have the rears fitted.
It wasn't untill i saw the car drop at the rear that i thought YES,with the new wheels it's going to be the big change that i said it would be :smug:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #105 on: 06 February 2011, 22:37 »
nice nice we expect vids uploaded as per course.. will it be long left or are the fronts quicker ??
Re: Big Changes
« Reply #106 on: 06 February 2011, 22:43 »
Still waiting for delivery of the fronts,but they should be with me in the next few days.All the hard work is pretty much done,the fronts are just a case of swapping the shocks over and plumbing in the air line.
The wheels have been a hassle,but the rears along with my custom 13mm adaptors have been completed,should have kept the csl's the amount of money it's taken but hey ho it should look good and be a one off.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #107 on: 06 February 2011, 22:46 »
so are the wheels now ready with rubber and adaptors or you waiting on front adaptors ??
Re: Big Changes
« Reply #108 on: 06 February 2011, 22:59 »
No,the wheels are 5X120 so using my current adaptors,but to get the rears to sit how i want them it required loosing 3mm off the offset.I had planned to have 3mm machined of the back of the rear wheels,but due to the spoke design it wasn't possible,a solution had to be found fast.The idea came up about taking 3mm off the adaptor but this would leave the bolts that hold them to the hub sitting proud 3mm(they can't be chopped down,for head strength),so it was decided that we should make little pockets in the back of the wheels to accommodate the bolts.Got the call earlier to say that they are finished.Rubber is here,just needs fitting.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Big Changes
« Reply #109 on: 06 February 2011, 23:08 »
bloody hell thats a lot of work.. hope its all worth it in the end mate..
