Author Topic: HOW TO - Dissable Auto Rear Wiper - VCDS Required  (Read 26757 times)
Offline The Doc
  • E63s Estate - Vito Sport
« on: 04 December 2010, 20:45 »
Hi all,
This simple post tells you how to code out the auto rear wiper when reverse is engaged.
Please forgive the long post for a simple task but it's so anyone can do it  :wink:
You will need VAG COMM or similar.
1.Open VCDS and selcet Select Control Module. Next Select Cent. Elect.
2. Once open select CODING
3. Once open goto line 3 then goto BYTE 21 on line 3 and and click it - It will turn yellow
4. Look at the options on the lower left and click Bit 6 i.e. UNTICK IT
Then it will look like this, click EXIT and hit DO IT - job done ;-)
« Last Edit: 06 February 2011, 10:48 by The Doc »
Offline p3eps
Re: HOW TO - Dissable Auto Rear Wiper - VCDS Required
« Reply #1 on: 06 December 2010, 18:11 »
Nice one... thanks.
That bloody rear wiper drives me nuts, so I'll be turning it off this weekend when there's some daylight for a few hours!
It looks like I might turn bit2 and bit3 off too - as I'd rather it never went off itself unless I specifically press the stalk!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline The Doc
« Reply #2 on: 06 December 2010, 22:36 »
At least you know were to look now :-)
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 19 December 2010, 18:00 »
I just did this to mine. Thanks for the info. :smiley:
Im not sure if i need to untick bit 2 and 3 as im not sure exactly when they do.
Do they meen if you have the front wipers on the back one will go every so often?
As i never noticed it do that but mine are both ticked. Maybe bit 6 has an effect on bit 2 and 3.
Doc hows your rear wiper acting since you did the coding?
« Last Edit: 30 December 2010, 11:20 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline The Doc
« Reply #4 on: 11 January 2011, 08:28 »
Rear wiper acting as normal minus the turning itself on when it's not raining.
I left bits 3 and 4 alone :-)
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 14 January 2011, 18:14 »
Thanks. I will just leave mine then  :smiley:
Current Garage:
