Author Topic: frozen washers  (Read 3828 times)
Offline dolphinfriendly1012
Re: frozen washers
« Reply #10 on: 02 December 2010, 22:04 »
low fluid level warning, which is ironic as you can't use them cause there frozen! :grin:
Offline tech1889
  • Mk2 GTI FTW !!
Re: frozen washers
« Reply #11 on: 02 December 2010, 22:04 »
hmm didnt know that will have to have a look the weekend for that..
Offline DmjButler
Re: frozen washers
« Reply #12 on: 03 December 2010, 13:47 »
Yea they have low fluid warnings too on winter packs... It is useful when your washers aint frozen - Cause then it'll alert you if your bottle needs filling  :smiley:
Offline Adam
Re: frozen washers
« Reply #13 on: 03 December 2010, 13:54 »
I dont have the winterpack but have the low fluid warning indicator.
The winterpack consists of heated washers, heated seats, and a headlight washer system.
Down Hill From Here.
Offline vwprime
Re: frozen washers
« Reply #14 on: 03 December 2010, 14:37 »
If you use the VW screen wash stuff its ok and don't frez up. Gives a better dove tail fan spray over the screen and smells quite nice. The truble is it cost quite a bit in contrast to othe stuff you might get from other places.
TRANSFORM, & ROLL OUT!
Offline Rhyso
Re: frozen washers
« Reply #15 on: 03 December 2010, 14:48 »
Less than £3 for 1.5 litres? Mine has lasted me a whole year  :smug:
Offline vwprime
Re: frozen washers
« Reply #16 on: 03 December 2010, 14:54 »
lol yet tell me about it Rhyso. I got some the other day. 5 bottles of the stuff as had to put some in the Golf and the TT. cost me £12.96  :shocked: :laugh:
Offline Rhyso
Re: frozen washers
« Reply #17 on: 03 December 2010, 14:56 »
That will last at least 5 years  :tongue:  Its almost as cheap as fuel these days  :laugh: :laugh:
Offline tech1889
  • Mk2 GTI FTW !!
Re: frozen washers
« Reply #18 on: 03 December 2010, 17:03 »
how i find out if washers heated should there be wires running under sound deadening under bonnet ??
Re: frozen washers
« Reply #19 on: 03 December 2010, 19:03 »
I read somewhere that it tends to be luck of the draw if your car has them ,i know I saw a bit on the r32 owners stating that none of the r32 had them fitted even though they had winter packs. It seems odd really, i have a h plated mk2 with heated washer jets!
I believe you can get hold of the loom from the stealer's as well as the jets, don't know the cost though apart from its a fiver a pair for standard. Don't know if you could modify a mk2 loom.
