Author Topic: Grand's 1.4 (NCB builder)  (Read 57221 times)
Offline GrandMstRamRod
dummy led 101
« Reply #60 on: 10 February 2011, 19:07 »
installing dummy alarm led!
1.
middle wire of the cigarette lighter i used red from led to red on lighter housing
2.
blue bullet connector for the 12v power from the ignition live
3.
4.
put all the stuff you took off back together!
cut the wire from cigarette lighter and used a standard connector to sew in new wire
Offline SoundillusioN
Re: Grand's Storm Grey 1.4
« Reply #61 on: 10 February 2011, 21:01 »
Not sure what you bought apart from it being a flashing LED, does it come with a trigger to switch on when igntion is off?... don't quite get the setup from the pics?
« Reply #62 on: 10 February 2011, 21:29 »
basically installed it into the 12v power supply from ignition positive and negative going to cigarette lighter yh its just a dummy alarm led!
« Reply #63 on: 10 February 2011, 21:35 »
Yeah I know but how does it work if it's wired to the ciggy lighter, you just got it flashing all the time?
« Reply #64 on: 10 February 2011, 21:38 »
only works when ignition is off its not wired to the 12v positive from cigy, its connect to the one next which is negative! and 12v from ignition live
« Reply #65 on: 10 February 2011, 21:42 »
Ah OK..... get some of THESE too then. :afro:
« Reply #66 on: 10 February 2011, 21:44 »
ha! nar alarm is on the way just as going Leeds for uni in September, and like f**k im going down there with no alarm just the strange people going round my area might as well look like my car is protected
coilovers arrived
« Reply #67 on: 16 February 2011, 17:40 »
coilover's arrived
before
after: the red wheel hubs will be going!
« Last Edit: 16 February 2011, 17:42 by GrandMstRamRod »
Offline Dmonday
« Reply #68 on: 16 February 2011, 17:43 »
Looks miles better :afro:
Offline shepgti
« Reply #69 on: 16 February 2011, 17:44 »
looking much improved, just needs wheels now :smiley:
