Author Topic: Grand's 1.4 (NCB builder)  (Read 61753 times)
Offline GrandMstRamRod
Re: Grandmstramrod mk3 1.4 budget! comments
« Reply #20 on: 22 December 2010, 11:33 »
just waste as little money as possible on it. whack some coilovers on it (keep the old shocks so you can put them back on when you get rid) dont bother with a vento front as ventos are sh!t and a vento front mk3 is even sh!tter (my opinon, scene queens will hate..)
go for a matt camo green!
out of intrest what brewery/pub are you manager of at 19..?
okells, its a isle of man company that have 42 pubs on the island and 5 in the mainland!
« Reply #21 on: 02 January 2011, 14:39 »
update this is new back box i got from ebay just after Christmas apart from i forgot to realise about the size of the pipes
the current diameter of the pipe on the car is 45mm and this back box is 60mm so going to get some reducers and flexi pipe so i can
propperly fit it!
also got some 55mm vw center caps for my alloys
Re: Grand's MK3 1.4
« Reply #22 on: 09 January 2011, 14:44 »
few more parts on there way from eurowagens.com
new front badge - NOT GETTING AS THERE OUT OF STOCK GOT REFUNDED
keeping with the standard style someone broke my lock pins so 2 of these
new side repeters as my are bust
plastic wheel arch's to give it the gti look - NOT GETTING AS OUT OF STOCK GOT REFUNDED
new spray nozzles
« Last Edit: 11 January 2011, 19:52 by GrandMstRamRod »
side repeater problem
« Reply #23 on: 11 January 2011, 17:40 »
difference in fittings for the bulbs so not 100% what i should do, i there cut out the fitting and replace it on the mk4 version!
Re: side repeater problem
« Reply #24 on: 11 January 2011, 19:39 »
Get mk3 ones, mine fitted straight in.
Re: Grand's MK3 1.4
« Reply #25 on: 11 January 2011, 19:54 »
shall be doing shame sort of liked these ones, but anyway got few more things to buy as eurowagens had not much in stock so got refunded a rather nice amount!
exaust today
« Reply #26 on: 13 January 2011, 17:14 »
first this to do is jack up the beast
bit of bodging as the current exaust is 45mm and back box is 60mm used  1 reducer and a flexi pipe
first try and make a custom hanger for the box, this was my first attempt ended up cutting the origional back box and got my brother to weld it to the stainless steel one
finished product will get better picture tomorrow
only one small problem is that the welding and sorting with the pipe is a bit well messy so needs tidying up
« Last Edit: 23 January 2011, 15:14 by GrandMstRamRod »
Re: suction
« Reply #27 on: 21 January 2011, 17:29 »
new air filter made out of
aspiro - 45 degree pipe with maf
aspiro - air filter
ash silicon - 90 degree 75 to 52 reducer
« Last Edit: 21 January 2011, 17:33 by GrandMstRamRod »
Offline shepgti
Re: Grand's MK3 1.4
« Reply #28 on: 21 January 2011, 19:44 »
hope your not planning on fitting an induction kit to a 1.4? that could be dangerous to peoples heatlh as they may laugh to death :undecided:
Offline LazyLunatic
  • MK3 20VT Project
Re: Grand's MK3 1.4
« Reply #29 on: 21 January 2011, 20:17 »
I had one on mine and I loved the sound of it :cry:
I actually had that exact same setup, except my silicon reducer was red not black.
