Author Topic: code reader recommendation  (Read 3086 times)
Offline ian007miles
Re: code reader recommendation
« Reply #10 on: 03 December 2010, 10:56 »
Cheers mate thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline ian007miles
« Reply #11 on: 03 December 2010, 11:12 »
Web I get one were do I find out wot all the codes mean
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #12 on: 03 December 2010, 12:22 »
Put them in google as.      Ross-tech ( code )
Offline richw911
« Reply #13 on: 03 December 2010, 17:57 »
Most of them are in the book which is supplied  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #14 on: 03 December 2010, 18:45 »
they are but not much of explanation or what likely to replace lol
Offline Ben Lessani
« Reply #15 on: 03 December 2010, 18:56 »
I've got a U281 and (recently) a ScanGaugeII .. http://www.ukobd.co.uk/Hand-held-Tools/ScanGauge2.html - a very nice toy!
If you're in Mancs, I can help you out.
Offline richw911
« Reply #16 on: 03 December 2010, 19:52 »
True  :smiley:
Offline M13LE U
« Reply #17 on: 03 December 2010, 21:17 »
my u280 arrived yesterday, the car had 2 codes. One code was in the booklet, the other i had to do a bit of research on. Basically my car runs a little rich which i knew cos I'd recently checked the spark plugs and they were a little dark. I am assuming that this has caused a sensor around the cat to get a little sooty and throw the engine management light on. I cant remember the codes that came up ill have to read the car again. The one that I had to do some research on said something like O2 sensor bank 1 after cat.
Offline Ben Lessani
« Reply #18 on: 03 December 2010, 21:55 »
po421 by any chance?
