Golf mk2
mk2 16v?? any nasty problems
Topic: mk2 16v?? any nasty problems (Read 1836 times)
alex160
25 November 2010, 19:49 »
Looking at a mk2 gti 16v tomorrow, might be getting as a restoration project, its a h-reg, 5 door, has done 160k though, do the 16v engines give much trouble? Better off looking for an 8V?
Thanks
Alex
2001 Golf GT TDi 150bhp/ 250 ftIb torque *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
The Mighty Elvi
I'm better than you today.
Re: mk2 16v?? any nasty problems
25 November 2010, 19:53 »
No trouble, get the 16v much better engine.
If its a "restoration" project then any old shed will do you fine.
However, The MK2 is built like a brick privvy. Buy on bodywork. Ensure its straight and has no/minimal rust.
Everything else - engine included - is easily repaired/reconditioned/replaced at minimal fuss & cost.
Use the search fucntion for MK2 buying tips.
Jonathan.
clipperjay
25 November 2010, 20:19 »
RUST
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
26 November 2010, 09:29 »
main thing is check when the belt was done, snapped belt = expensive on a 16v.
dragonfly
26 November 2010, 10:02 »
Oil leaks from the dizzy. Check for splits on the air ducting which along with damaged vac hoses make the 16v run rough.
Neo Badness
Feet are for pedals
27 November 2010, 12:42 »
Quote from: clipperjay on 25 November 2010, 20:19
RUST
+ 1, in the process of replacing/ rectifying previous repairs on mine. If I'm lucky I may retain 70% the original metal
My advice would be buy the least rotten one you can. And make sure if it's a 16v that the belt, tensioner and water pump were done within living memory. 4yrs or 40k whichever is sooner. Also make sure they used the proper waterpump with the metal fins rather than the cheap tat one with the plastic fins as they break down over time and you can imagine how good bits of molten plastic are to have floating round the cooling system.
Golf mk2
