Author Topic: VR6 break upgrade.....  (Read 1500 times)
Offline flash-derby
« on: 21 November 2010, 20:48 »
ok i've done a search ok the 311mm link in info don't work........
so, how hard is the VR6 break upgrade and are they loads better?
cheers peeps.
if its got pistons or tits, either way its gonna be expensive
Re: VR6 break upgrade.....
« Reply #1 on: 21 November 2010, 21:40 »
Vr6 is the same size as a later 8v 288mm.
Offline Gervais
« Reply #2 on: 22 November 2010, 15:30 »
I've heard that using 312mm discs and carriers are a good upgrade, can use your standard claipers too. Was looking into this for mine but now I might be selling I probably won't be doing it.
Offline flash-derby
« Reply #3 on: 22 November 2010, 23:44 »
what would the 312 breaks come off?
and mines a n- reg so i guess mine are smaller?
Offline Ess_Three
« Reply #4 on: 22 November 2010, 23:53 »
Mk4 Golf Anni (petrol), Mk4 4-Motion, Mk1 S3, Mk1 TT.
You need the calliper carriers and discs, plus a 6mm spacer between the hub and calliper carrier to sort the offsets out.
Callipers are the same, as are pads & brake lines.
Quote
Yup, 288mm...but should have the correct callipers.
..but gaining motorcycles.
« Reply #5 on: 22 November 2010, 23:59 »
To be honest unless your running mega bhp the 288 set up is fine.
Offline flash-derby
« Reply #6 on: 23 November 2010, 18:00 »
yeah but would look sweet as fooook tho  :wink:  lol
« Reply #7 on: 23 November 2010, 21:39 »
Still not really needed.
Offline justalex81
« Reply #8 on: 24 November 2010, 09:16 »
uprated discs and pads will be fine.
your brakes are only as good as the tyres so make sure you have wide tyres with lots of grip.
Offline Len
« Reply #9 on: 24 November 2010, 12:19 »
The first link in the Sticky thread may not work anymore but ALL the info is still there if you care to read it! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
