Golf mk3
hardmonkeys
Bleeding Brakes
Topic: Bleeding Brakes (Read 2301 times)
MowatGTI
Re: Bleeding Brakes
Reply #10 on:
24 November 2010, 18:34 »
I sure do.
Why? Please tell me you know something i don't!
Please!!!!!!
javalin
Re: Bleeding Brakes
Reply #11 on:
24 November 2010, 20:28 »
if you've emptied, or induced air into the system - I believe you have to put the pump into "being bleed" mode. You'll need VCDS (Vagcom) for that.
http://www.ross-tech.com/vag-com/cars/absbleeding.html
James
Last Edit: 24 November 2010, 20:30 by javalin
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
MowatGTI
Re: Bleeding Brakes
Reply #12 on:
24 November 2010, 22:36 »
Oooohhh - cheers.
Another thing i've realised is that because I've changed the pads and not the discs - a pad might be riding a groove on the disc and springing back on the piston.
Will check out both and post back when its sorted.
Golf mk3
hardmonkeys
Bleeding Brakes
