Author Topic: Door lock problem  (Read 3269 times)
Offline intenso
Door lock problem
« on: 20 November 2010, 12:38 »
Hey i just noticed today that the lock on my driver's side door does not work, when i put the key in it just turns and turns but doesn't lock/unlock although the key fob still works for locking/unlocking so must be a problem with the actual lock mechanism.
Any idea what the problem is and if i can diy it or should i take it to the garage and how much a garage is gonna skin me ?
Offline farmerpalmer
  • GTI 30 Edition, Reflex Silver, MFSW, Xenons, cruis
Re: Door lock problem
« Reply #1 on: 20 November 2010, 18:15 »
Have a quick search, as others have had the same issue.
I had the same problem a little while ago, and used wd40/ spray grease into the lock and remove the bung and spray in there. Touch wood, this has solved the problem for me.
GTI 30 Edition, Reflex Silver, MFSW, Xenons, cruise, iPod & armrest.....and a tank full of 99 octane
Offline intenso
« Reply #2 on: 20 November 2010, 20:31 »
Had a look in the mkv forum but couldnt find anything similar.
The lock has not siezed, the key goes in the barrel fine and it turns freely it just doesn't lock the car.
Offline mortygt140
« Reply #3 on: 29 November 2010, 14:44 »
Sounds like the lower part of the lock cylinder has snapped off??? If you open your door and look down the edge of it there is a black plastic cover that goes down the length of the door, take this off.
Then there is a small round piece of what looks like duct tape?  take this off aswell and inside that you should be able to make out a T20 torx screw, firstly pull the door handle out and hold it there then get your T20 driver and turn the screw in the door anti clockwise this will release the door lock.
Examine the lock cylinder and tumblers for any damage and also make sure it has the end on it???? if you look into the door where the lock was you will see where the lower part of the lock cylinder goes and turns the mech to unlock/lock the door.
Hope this helps
Darren
Offline Saint Steve
« Reply #4 on: 30 November 2010, 19:01 »
Sounds like the lower part of the lock cylinder has snapped off??? If you open your door and look down the edge of it there is a black plastic cover that goes down the length of the door, take this off.Then there is a small round piece of what looks like duct tape?  take this off aswell and inside that you should be able to make out a T20 torx screw, firstly pull the door handle out and hold it there then get your T20 driver and turn the screw in the door anti clockwise this will release the door lock.
Hope this helps
Darren
How easy is this to remove darren?
Whats needed?
Offline mortygt140
« Reply #5 on: 02 December 2010, 12:53 »
Very easy Steve just get hold at the bottom of the plastic piece and pull down and out its only held on by plastic clips.
Darren
Offline Saint Steve
« Reply #6 on: 02 December 2010, 13:24 »
Darren
cheers Darren  :cool:,
 although cant open the door at all now, has been snowed shut!!!!  :laugh:
Offline intenso
« Reply #7 on: 09 December 2010, 01:22 »
Thx for the tip, stil aint had a chance to check yet with all this sh!tty weather  :laugh:
Offline intenso
« Reply #8 on: 11 January 2011, 16:09 »
Finally got a chance today to take out the barrel, was an easy job.
Turns out something inside the barrel is broke as the end bit doesnt turn when i turn the key although physically it looks ok,  Are barrels easy to fix if i get another from the scrappy or will i need to throw monies at the stealers ?
