Author Topic: Arch Extensions  (Read 2284 times)
Offline vwprime
Re: Arch Extensions
« Reply #10 on: 19 November 2010, 15:22 »
Another option is to get diffarant tyers. The wheel can stick out but as long as the tread is under then arch its ok and will pass. There will be a lot of strech on the tyer thow.
A little like this  :smiley:
TRANSFORM, & ROLL OUT!
Offline daz veedub
  • Operation 1.8t bolf
Re: Arch Extensions
« Reply #11 on: 19 November 2010, 15:57 »
camber is an option
Offline Alexx
Re: Arch Extensions
« Reply #12 on: 19 November 2010, 16:46 »
Well your only option is to mod the arches, they might be nice but having to run a 15mm spacer is not good.
[/quote]
thats what im thinking but I cant find any decent mods for the arches. whats bad about spacers? extra strain on the suspention?
"If in doubt, flat out"
Offline tech1889
  • Mk2 GTI FTW !!
Re: Arch Extensions
« Reply #13 on: 19 November 2010, 17:24 »
Spacers are not such a big problem you can get like 50mm Spacers there will more strain on components just by lowering 10mm . Your wheels sticking out is a problem all I can think is get your arches rolled and flared.
Offline Adam
Re: Arch Extensions
« Reply #14 on: 19 November 2010, 17:38 »
A lot of strain on wheel bearings.
Down Hill From Here.
Offline Alexx
Re: Arch Extensions
« Reply #15 on: 19 November 2010, 17:41 »
im in Edinburgh and there are not that many garages here (Ive only recently moved but still...) that would do such a thing. most bodywork shops either say its too complicated or the price is 300-400 per arch which I find is a bit too steep even though they might have to spray paint.
Offline Alexx
Re: Arch Extensions
« Reply #16 on: 19 November 2010, 17:45 »
If I was to stick a piece of thick plastic under my arch so it just covers the wheel, would that constitute to my wheels not sticking out from under the arch?
Offline Dave_IOW
Re: Arch Extensions
« Reply #17 on: 19 November 2010, 18:28 »
Honestly mate, cant you find a set of steelies local you can buy, or borrow some wheels from a mate or something?
Flared arches are real nice and all that, but i wouldnt go through all that just to pass an MOT?  :huh:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline tech1889
  • Mk2 GTI FTW !!
Re: Arch Extensions
« Reply #18 on: 19 November 2010, 19:06 »
I would just buy some cheapo wheels or like £80 an then just swap after mot.
