Author Topic: urgent help on gti 8v  (Read 1974 times)
Offline tenere
Re: urgent help on gti 8v
« Reply #10 on: 19 November 2010, 19:25 »
if your power steering goes ,more so on right turns ,whilst the engine is still running and its raining i would suspect the pas belt,if the same happens when its not raining i would look for coolant dripping onto the belt.,,this is from my own experience.new belt and water pump solved it for me.
Offline shazz290
« Reply #11 on: 19 November 2010, 19:43 »
happens on left and right turns, its been raining everytime i drive it so dont about when in dry weather.  Also realised when i pick up speed and brake light and make a tight corner the steering loses power and when turned in the steering returns to normal.
Offline shazz290
« Reply #12 on: 20 November 2010, 18:38 »
mechanic gave it a once over and said the only thing he can spot is that the throttle body needs cleaning everything else is fine. £20 to clean the throttle body?
« Reply #13 on: 22 November 2010, 11:17 »
always worth doing :)
Offline shazz290
« Reply #14 on: 22 November 2010, 13:57 »
up for sale £575 ono
Offline javalin
« Reply #15 on: 24 November 2010, 12:28 »
Check the crank sensor wiring - common ish fault as it (and wiring) is underneath the car.  I.e. if its damaged, in the wet it shorts and cuts the engine.
Mine looked like - http://javalins.wordpress.com/2010/03/13/dodgy-sensor-wiring/
I remember a few cases of this on this forum last winter.
Didn't cut out, but was a PITA to drive.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
