Author Topic: help or its gettin burnt out !  (Read 2113 times)
Offline houston
Re: help or its gettin burnt out !
« Reply #10 on: 15 November 2010, 23:28 »
did you check the centre pipe bracket on the exhaust like i said last time?
Offline The Dave
« Reply #11 on: 16 November 2010, 00:15 »
Flywheel? ;)
Offline jonnyturbo
« Reply #12 on: 16 November 2010, 10:48 »
Been under car today and only thing I could see loose was under tray. Fixed that. Dogbone seems fine heat shields are ok.  Can't be the flywheel because rattle was there even before I coverted to a solid mass.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #13 on: 16 November 2010, 11:07 »
Take dog bone off and split it apart they look ok but rubbers still might be bad.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #14 on: 16 November 2010, 13:20 »
also check the rubbers in the top engine mount on passenger side.
Another thing maybe worth checking is wishbone bushes if your on standard ones. Get someone to drive your car forward slowly and see if you notice vibration in the wheel.
Offline jonnyturbo
« Reply #15 on: 16 November 2010, 15:57 »
Lol been to 2 more garages today and both said rattle is comin from gearbox / diff . I am sick of it :(
Offline Hulmie
« Reply #16 on: 16 November 2010, 16:06 »
is the diff at fault? clutch, gears, flywheel etc my be fine.
Offline jonnyturbo
« Reply #17 on: 16 November 2010, 16:16 »
You would think diff would be fine as its a totally reconned box. Going bk to place where I got box from tmra
Offline Hulmie
« Reply #18 on: 16 November 2010, 17:20 »
are the driveshafts and cv joints ok?
Offline jonnyturbo
« Reply #19 on: 16 November 2010, 17:30 »
Rattle goes away when left lock is applied.  So I thourt driveshaft so I replaced it along with bearing. And still the same  :undecided:
