Author Topic: Fan not workin  (Read 1577 times)
Offline gover87
  • mk3 gti 16v
Fan not workin
« on: 14 November 2010, 14:43 »
Can some 1 plz tel me how to test the fan on my mk3 gti 16v, it doesnt come on wen the engine is hot. It doesnt overheat but stil want the fan workin lol
Offline AlexMozza
Re: Fan not workin
« Reply #1 on: 14 November 2010, 15:00 »
Turn it on and leave it running. Don't drive it, after about 20 mins the fan should just start :)
Edit - Keep an eye on the temp as you dont want it to Over Heat :O
« Last Edit: 14 November 2010, 15:17 by AlexMozza »
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline gover87
  • mk3 gti 16v
Fan not workin
« Reply #2 on: 14 November 2010, 15:08 »
Ok al try that, also i have unpluged the air mass sensor and it has stopd the lumpy idling etc but wot does this mean? I gues u cnt just leave it unplugged
Offline AlexMozza
Re: Fan not workin
« Reply #3 on: 14 November 2010, 15:18 »
Could give the TB a clean/ check if there's anything in the filters?
2001 Satria GTi
Formula 3 Mechanic
Offline gover87
  • mk3 gti 16v
Fan not workin
« Reply #4 on: 14 November 2010, 15:22 »
Sorry bt wots the tb? Also the filters are all clean did that the utha day m8. Does it hurt 2leave it unplugd? Sorry if its a stupid question, it has given it more power in lower revs aswel :-)
Offline AlexMozza
Re: Fan not workin
« Reply #5 on: 14 November 2010, 15:24 »
TB - Throttle Body.
The Air Mass, allows the ECU to adjust how much fuel is needed to mix with the air, without it it dumps to much petrol in and that could damage the CAT if left for a while :(
2001 Satria GTi
Formula 3 Mechanic
Offline dom
  • Back in a Mk4
Re: Fan not workin
« Reply #6 on: 14 November 2010, 15:24 »
I'd plug your air mass sensor in and get it replaced asap, tb = throttle body, give it a good clean with carb cleaner there's a guide on here somewhere if you search for it.
As for your fan i'm pretty sure mine kicks in when the oil temp hits 104  :smiley:
Offline AlexMozza
Re: Fan not workin
« Reply #7 on: 14 November 2010, 15:27 »
For a New air mass filter, check the classified, someone prob have one there for next to nothing :)
2001 Satria GTi
Formula 3 Mechanic
Offline gover87
  • mk3 gti 16v
Fan not workin
« Reply #8 on: 14 November 2010, 15:28 »
Oryt its nt bin at that temp yet lol, and  il try them utha things cheerz lads
Re: Fan not workin
« Reply #9 on: 14 November 2010, 15:29 »
Nope needs replacing
